  • 2 years later...
Hello to all..
I bring up this topic again and post two pics to have info about this type of edge:
Can you give me some directions to do the same with my straps?
Thanks to all
Click on pics to enlarge
Edited by Qbacce
Yes, stop using that gum tragant. I cant really see any advantages with this product, must be on certain leathers that will not burnish with anything else. You can use saddle soap, but the best thing is to stick to water alone. Then you keep your burnisher clean too. I do not want to use anything else than water on my new cocobolo burnisher. Then I keep it clean for fat and do not have to sand it all the time to make it burnish well. In addition the Fibings edge cote want come off either. Sometimes I use alcohol based dyes before burnishing, that will ease up the burnishing process and remove fat. Oil/fat and wax must be applied after the the edge cote and not before.
There are an other option too, you can move on to heat treatment of your edges. Then you must move on to professional edge paint. You will have to invest in a hot glazing tool/machine or a "Filet electric" in French. Check out the topics about it or contact Campbell Randall. It will work on chrome tan leathers too.
Very nice color on your watch straps, are they all Fibings?
Tor
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Thank for reply, they are not my creations..
I was asking for directions to do an edge finishing like those in pics..
So: burnishing with water and saddle soap, apply an acrylic paint than resolene/edge kote could be a solution???
Luca
Ps what is franch traditional tecnique??
Edited by Qbacce
  • 4 weeks later...
Hi, you can check what I'm using http://www.fenice.com/index.php/en/63-slide-immagini-what-s-new-inglese/630-section-lacquers, Tandy used to sell those under name Professional edge paint (not anymore ?)
