Members lairdstew Posted August 9, 2012 Author Members Report Posted August 9, 2012 From the old grump: Looks like you did a good job, your workmanship is pretty damned good, but two things pop out at me. First, it appears that the mag release is covered - which ain't too good a thing. You can end up with a missing mag, or, as you draw, the mag can decide to hit the floor, dirt, gravel, or roadway, leaving you with one round in the shooter and egg on your face -- if on the range. But if in a personal defence situation, things can get real icky-poo in a hurry if that happens. The other thing is that the rear sight is quite exposed - allowing for dings, bangs or thumps resulting in damage to it, just from walking around. Also, being exposed, it will provide for a lot of torn shirts, and/or jacket linings when worn concealed. The sharp corners sticking out there seem to like to tear stuff up pretty quickly. Overall, not a bad go at things, just a little tweaking of the pattern and you have a winner, JMHO. Mike Thanks for the input. So, should I just cut out the sweat guard a little to not cover the mag release? Like a notch or something? As for the sights, should I make the holster flare up so that it hits right underneath the rear sights? Laird Quote
Contributing Member TwinOaks Posted August 10, 2012 Contributing Member Report Posted August 10, 2012 Yes, you can just rebate the back side of the holster to give clearance for the mag release. Also, can you get a full firing grip without interference from the holster? If not, you can lower the area directly to the left of the trigger guard (as the holster is oriented in the pic), a light bit more and give yourself the room you need.The design looks solid and the only other things I see to comment on are PURELY aesthetic. The 'front' of the holster looks longer than the rear portion, which makes the holster appear slanted. That may be just a picture angle, so if it's pretty even across the bottom, just ignore this one. Last thing: Corners. Leather corners ('outside corners, that have a point) are bad, and on the frame of the inlay, at the junction of the trigger guard and dust cover, that little point has the potential to get lifted, dog-eared, and possibly snag clothing. 20 seconds with a razor to round it, and a minute to reburnish that spot would finish it up. Overall, REALLY NICE LOOKING HOLSTER. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members katsass Posted August 10, 2012 Members Report Posted August 10, 2012 Thanks for the input. So, should I just cut out the sweat guard a little to not cover the mag release? Like a notch or something? As for the sights, should I make the holster flare up so that it hits right underneath the rear sights? Laird From the old grump: I make very few true pancake holsters anymore, however, here is a pic of a little pancake I made some time ago for an old Llama .380 which is a mini-clone of a 1911 auto, so the only difference is size. . The mag release is free and the sight covered, The customer demanded the safety strap. Hope this helps a bit. Mike Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
Members lairdstew Posted August 10, 2012 Author Members Report Posted August 10, 2012 Twin Oaks and Katsass, thanks for the input. This is the first time I made this exact pattern and I will be sure to include your input when I make it again. The right side of the holster does dip a little lower so that will be something to pay attention to next time. I can get a decent firing grip on the gun but I think it could be a little better. I will dip that side down a little and raise the other up to protect the rear sights. One of the more recent holsters I made was for a Kahr p380 and I had to make that thing three times to ensure ample grasping room. What a pain! Thanks again for the help. The members here have provided an invaluable resource for us enthusiasts! Laird Quote
Contributing Member TwinOaks Posted August 10, 2012 Contributing Member Report Posted August 10, 2012 The way to get around multiple makes of the same holster is to use a GOOD glue and check your grip before stitching. The glue won't hold up long term, but will be sufficient for keeping the halves together while you 'tweak' the lines. Once you've done a few with plenty of room for the grip, you'll get an eye for it when you do the initial layout. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
