chainedrose
Help Please..
im using 6 strands for this braid, 3 on each side. black, brown black in that order.
i started from the left hand side, took the farthest (first strand) behind to the right hand side, took it under, over, under, back to the left side. then repeated similarly for the top most on the right hand side. took it to the left, under over under the 3 left hand side strands and back to the right side.
now the front side looks like the first pic. while the back side looks different. why? what happened here? what went wrong?
post-21312-001820300 1344718371_thumb.jp
post-21312-079950100 1344718400_thumb.jp
IIRC, for 6 strand round braid, you alternate the pattern when you switch sides. For example: From the left, go around and O-U-O; from the right, go around and U-O-U.
I'm thinking it's OUO both ways, just like 12 in pairs is OUO each side. Or UOU whatever you start with. I just finished a 12 strand Roo bosal in pairs that was UOU. I think if you do U2 and O1 each side you end up with one side flat. Brad
Turns out that there's more than one way.....I was thinking of the u1, o2....u2,o1 version.
Here's something that should help..........http://www.lbbyj.com/index.php?main_page=page&id=2
so i did start wrong! :( i even have the Ron Edwards book but i didnt refer to it! :( feel like such a fool now!
