Members ThBrtmn Posted August 29, 2012 Members Report Posted August 29, 2012 Hello, Im looking for some information and help on Pull the Dot snaps. I was able to find PTD snaps online but for the life of me I cant find the ones that are adjustable with the screw in the middle. What Im looking to do is create a and adjustable strap like whats used in an IWB holster. Also if anyone has any info on how the assembly goes, I would greatly appreciate it. I know how to crimp snaps but not sure how the screw is involved? Does it just Screw into a normal stud/post? Just trying to work it so it doesnt poke through the back... Any help would be greatly appreciated. Quote
Members Matt Alsaker Posted August 30, 2012 Members Report Posted August 30, 2012 I'm not sure if this is what you were looking for, but I use PTD snaps on my IWB holsters. I insert a t-nut between the two pieces of leather on the body of the holster. I then secure the belt loop with a PTD stud to the t-nut with a SS screw. I use removable loctite to secure the screw into the t-nut. Quote http://www.alsakercustomleather.com/ https://www.facebook.com/AlsakerCustomLeather?ref=hl
Members ThBrtmn Posted August 31, 2012 Author Members Report Posted August 31, 2012 (edited) I'm not sure if this is what you were looking for, but I use PTD snaps on my IWB holsters. I insert a t-nut between the two pieces of leather on the body of the holster. I then secure the belt loop with a PTD stud to the t-nut with a SS screw. I use removable loctite to secure the screw into the t-nut. Thanks for your reply Matt... Question for you... With a Tnut, I assume it is removeable to adjust to different holes. From the picture it DEFINATELY looks like what I'm shooting for. The only think that I see is that your Leather is THICK and therefore unless its a shorter post on the Tnut, it may be a little longer than my application needs. It will go through a .060-.080 kydex and then about 1/8" leather. You wouldnt happen to have any part #s would you? I have found this web site with some PTD pieces. http://search.sailri...s%20%26%20Hooks You wouldnt happen to also have a few more pics maybe with the mechanism pieces all (other than the snap button) apart and sitting side by side? Thanks again Edited August 31, 2012 by ThBrtmn Quote
Members Matt Alsaker Posted September 2, 2012 Members Report Posted September 2, 2012 I purchase t-nuts and SS machine screws from the local hardware store. The t-nuts are 6-32 x 1/4" and the screws are 6-32 x 1/2", although a 3/8" screw will work. My t-nuts are NOT removable, as I sandwich the t-nut between the two pieces of 6/7 oz leather I use to make the body of the holster. The back of the t-nut is not exposed on the outside of the holster. I know some guys make their IWB's with the t-nut exposed on the outside of the holster. I've read a couple posts on this forum discussing the merits of both. The riser I use between the belt loop and the belt loop its self are made of 6/7 oz leather., so I have about 3/8" of leather I go through (3 layers of 6/7 oz). I use PTD studs (92-BS-18303-1C) that I ordered straight from the manufacture. The stud adds approx another 1/8", for a total of approx 1/2" of thickness. It sounds like the material you are going through is a lot thinner. I don't recall seeing a t-nut with any shorter post than I am using, but I could be wrong. I don't have any pic's of the construction process and don't have an IWB laying around right now. Hope this helps a little. Quote http://www.alsakercustomleather.com/ https://www.facebook.com/AlsakerCustomLeather?ref=hl
