chouinardragon Report post Posted September 28, 2012 Hello guys, I have been using saddler's clamp instead of stitching pony for a while. I use Vergez Blanchard's saddler's clamp and their 38mm awl. I have problem with it. I can't stab the awl vertically to the leather because of the direction of the awl in my hand. I also have no ideas of what direction should I push the awl blade while I stab. Should I adjust the way I hold the awl or the way of the saddler's clamp between my legs? Thanks! Quote Share this post Link to post Share on other sites
steveh Report post Posted September 28, 2012 If you are new to this sewing technique,it will take some practice to get the hand coordination of the thread the and the needles mastered.. the clam that you are using uses your leg pressure to hold you work firmly. The left side or the blind side canot be seen, so as you stab your awl your needle in the left hand must follow the awl as you pull it out. I assume that you are marking stitches with a pricking iron or stitching wheel. The awl makes a diamond shaped hole in the leather, make sure that flat of the diamond follows you stitch line with a continious angle. You want to hold the clam with legs so that is perpendicular to your sewing hand. I not totally clear on your question, I hope this helps. steve Quote Share this post Link to post Share on other sites
chouinardragon Report post Posted September 28, 2012 thanks steve, and sorry for my poor English, I'm not native speaker. In short, 1) I don't know the correct way to pose the saddler's clamp (angle). 2) I don't know how to pose my right hand on the saddler's clamp (toward the leather? toward the front?). 3) I don't know which way I should push the awl while stab. By the way, I flated the awl blade so it is not diamond shaped, more like eye-shaped. Does it matter? Quote Share this post Link to post Share on other sites
js2rt Report post Posted October 6, 2012 This link may help you see how the clamp is used. http://leathertools.jp/?pid=7738310 Quote Share this post Link to post Share on other sites
chouinardragon Report post Posted October 9, 2012 Thanks buddy. I sit on a normal chair while I do stitch, not a stool. Does it make any difference? Quote Share this post Link to post Share on other sites
