You could do it with those plain (open / no center bar) rings...round or square...but remember to allow for the fold around each one. I'm guessing that you'd probably need 4 1" rings per side to stretch the belt 4 inches......because you'll use ~1/2" at each fold.
Mike DeLoach
Why 4 rings? Are you thinking for her to make up all the space with the rings, or adding new leather to make up the length and using the ring as a method of attachment? I was thinking the latter.
I thought you were suggesting making up the space with rings. That way, the original belt is the only leather used and removes the need to try and match the color.
I can certainly see the merit of only using them to add new pieces. As long as the color/stamping is repeatable, then the latter will definitely be faster and easier.
Mike DeLoach
I hadn't thought about matching the color. I suppose if it were really custom it might be a little bit of a pain.
I'm just glad to hear that others think it's a viable idea since I hadn't had a chance to try it yet :)
I actually, just happen to have another unfinished belt that I dyed from the same leather, and stamped and stained. Twice the work, but because I was worried about getting the belt out in time, I figured it was good insurance, just in case....so looks like it came in handy.
