Hi guys my first project was an epic fail but I bit the bullet dyed the price but I'm really not happy is their anything I can use to strip the colour off and try again
Any advice welcome
It depends on how you dyed it. I've used "liquid latex" before to completely pull ALL the dye off a piece before.....which is a shame because I was only trying to mask an area with it. But the results still stand.
If you've already sealed it, you can try some deglazer to remove the top coat...but it's a pretty harsh chemical. Work in a well ventilated area, and you'll need to re-condition the leather after using it.
As a last resort, there is always Fiebings USMC Black. If you finished it, take the finish off with deglazer as stated above, then dye it black. If you haven't put a finish on, just dye it black.
Chief
Yessir "Cheif" is right. Although if ye ole USMC Black doesn't cover it up there is basically no hope.
