Cutting Fringe...June Taylor Quilting Template...Many different templates to choose from, so read carefully about which one you choose...Rotary Cutter, be sure to get one with a bigger blade...One Template cuts 1/4 inch strips, most cut 1/2 inch strips...I used the 1/4 inch Template and went back and cut 1/8 inch strips...The cuts are clean and crisp...To make longer fringe, (1/4 inch Template is only 6 inches long), I carefully moved the Template and cut longer...I have cut 3 pieces of leather at a time with great success. I found this to be much faster and safer than using a ruler. I have learned so much from this site and I hope this will help someone else.
Edited by Newbee
Learning Granny
