Members BulletProof Posted November 23, 2012 Members Report Posted November 23, 2012 I am getting a maker stamp made and I want to know what is the minimum size type that I can clearly impress into the leather? I am hoping someone can give me a size in "points" so I can set up the vector design for the custom stamp. Thank you! BP Quote
Members lwleathers Posted November 23, 2012 Members Report Posted November 23, 2012 Hi BP, Usually for a clear emboss, the strokes of your design or text should be AT LEAST 0.5mm. Although our CNC machines can be as precise as 0.3mm, we don't suggest our clients to go this small. Since different fonts have different size of strokes, it is not accurate to refer the min. type size for a clear emboss. So how big is your stamp gonna be? You are welcome to send us the artwork to calvin@lwleathers.com and we can check if it will give a clear emboss on leathers. Quote Cheers, Calvin www.lwleathers.com Custom Stamps - Heat Emboss - Branding Tools
