Rolf Report post Posted August 13, 2008 Does somebody use a dremel www.dremel.com to burnish and "sand" the edges? Any clues are welcome! Thanks in advance for your valuable support. Rolf Quote Share this post Link to post Share on other sites
BradB Report post Posted August 13, 2008 Does somebody use a dremel www.dremel.com to burnish and "sand" the edges? Any clues are welcome! Thanks in advance for your valuable support. Rolf Hey Rolf! Here is a whole thread on the subject: http://leatherworker.net/forum/index.php?s...7&hl=dremel Also just a couple of days ago someone posted a picture of a tool they made to use with there dremel for burnishing. Hope that helps! Regards, Brad Quote Share this post Link to post Share on other sites
Michael Sheldon Report post Posted August 13, 2008 I use one with a sanding drum for shaping edges on smaller pieces. But personally I feel, it's too small, too fast, not powerful enough for burnishing. Quote Share this post Link to post Share on other sites
whinewine Report post Posted August 13, 2008 Does somebody use a dremel www.dremel.com to burnish and "sand" the edges? Any clues are welcome! Thanks in advance for your valuable support. Rolf I have several burnishers of various groove sizes specifically made to fit the dremels [& foredoms (sp??) & similar hand-held tools] that I use all the time for burnishing & dremel itself has two different sizes of drum sander with (I believe), 2 different grits available. When you're doing production work, it just makes life much easier. With the variable dremels, you can step down the speed considerably & also change all the tools with a simple twist of the fingers (no wrench needed). Quote Share this post Link to post Share on other sites
jhinaz Report post Posted August 13, 2008 That handmade Dremel burnisher (a thread from a couple days ago that BradB referred to) can be seen on 'Leatherwork Conversation' / 'Custom Tools'. - John http://leatherworker.net/forum/index.php?showtopic=3556 Quote Share this post Link to post Share on other sites
Rolf Report post Posted August 20, 2008 Hey Rolf! Here is a whole thread on the subject:http://leatherworker.net/forum/index.php?s...7&hl=dremelAlso just a couple of days ago someone posted a picture of a tool they made to use with there dremel for burnishing.Hope that helps!Regards,BradThank you very much Brad. I'll try it out. Best regardsRolfI use one with a sanding drum for shaping edges on smaller pieces.But personally I feel, it's too small, too fast, not powerful enough for burnishing.Thanks Michael. What kind of Sanding drum are you using? Quote Share this post Link to post Share on other sites
Rolf Report post Posted August 20, 2008 I have several burnishers of various groove sizes specifically made to fit the dremels [& foredoms (sp??) & similar hand-held tools] that I use all the time for burnishing & dremel itself has two different sizes of drum sander with (I believe), 2 different grits available. When you're doing production work, it just makes life much easier. With the variable dremels, you can step down the speed considerably & also change all the tools with a simple twist of the fingers (no wrench needed).Thank you very much for your replay!That handmade Dremel burnisher (a thread from a couple days ago that BradB referred to) can be seen on 'Leatherwork Conversation' / 'Custom Tools'. - Johnhttp://leatherworker.net/forum/index.php?showtopic=3556 Hi John, thanks for your answer and the link! Quote Share this post Link to post Share on other sites
Michael Sheldon Report post Posted August 21, 2008 What kind of Sanding drum are you using? I use the standard dremel drums, medium or fine depending on the leather I'm working on. Quote Share this post Link to post Share on other sites
