Good find for you and great to give an old machine a proper home. It looks like you cleaned it up well!
A little sad the seller couldn't make a go of his business, but at least the tool didn't go into the hands of creditors
Really great job! Gives me an idea too about making something smaller than a 20 ton hydraulic press ... Gearbox, eccentric, ...
Tom
Thank you Tom,
If anybody can do it, you can. Its a simple construction. The secret lays in the big heavy flywheels motion, that exchanges in to a short movement of the press head, true a crank that moves the big column up and down. The (bicycle) crank works as a gear/exchange arm. A small stud with a spring loaded return comes out and lock the big flywheel to the main shaft when you activates it. Its kind of an reversed bicycle mechanism. Here you see the development history of their machines, http://www.schoen-sandt.com/company/about-us/development-of-cutting-machines.html
I have seen people still uses the first kind of press; the 1867 screw press. They rapidly spin the big wheel to make it more powerful, Its mostly used for embossing. You still find it in Asia and Africa, I have seen they put more weight on the wheel and extend its diameter to make it more powerful. I wonder where all these old mechanical and electro mechanical presses are today, they are maybe been turned in to nails. Its about impossible to break their sturdy construction. Its possible some hidden around in basement and barns somewhere, all you got to do is looking. I know this one works very well.
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Thank you, its a sad story. However, he still do leatherwork, but not as a professional. Norway is not a easy country for small businesses, its the same expenses to run a one man show as it is with ten employees.
Tor
Tor
