raysouth Report post Posted March 11, 2013 I have a new and unused, 12 ton shop press from Harbor Freight that is for sale. Thought I might make a clicker. Would be best if could be picked up in Opelika, Alabama as shipping charges would be costly, I assume. I paid sale price of $129.99, plus tax and their 6.99 shipping charge. (Wish I could ship it that cheap.) First $100.00 owns it. I did partially assemble the press but never completed. It can be taken apart again, if handling would be easier. Drop me a note if interested. Ray Share this post Link to post Share on other sites
CobblinHood Report post Posted March 21, 2014 Did it not work for you as a clicker-like tool? Share this post Link to post Share on other sites
CobblinHood Report post Posted March 21, 2014 I have actually been thinking about using this shop press as a sole press in a shoe repair shop. How much drop did you get out of the press shaft? Share this post Link to post Share on other sites
chrstn53 Report post Posted March 30, 2014 CobblinHood I turned a harbor freight shop press into a manual clicker press. I click small dies up to large bag panel parts without any problems. There is a slight learning curve on placement and knowing if you will need to click half the die and move it over for the other half. I cut off the bearing shaft and welded a 1" thick steel plate on the bottom cross arm and a 1/2" thick steel plate on the top and added two more springs to help take the stress off the hydraulic cylinder. I stacked two 1" hdpe plastic sheets and I can use my shortest dies to my old school steel rule mounted in wood dies. Share this post Link to post Share on other sites
CobblinHood Report post Posted March 30, 2014 @chrstn53 Heck yeah! That sounds pretty reliable. How of a drop do you get out of the shaft? 6" or so? less? Just curious because I want to mount a high density foam brick to a plate and attach it to the shaft to be used as a shoe sole press in a shoe repair shop. I am going to mount a cobbler's anvil under the shaft but I would probably need about 4-6" of clearance (at least) when the press is off the anvil. Share this post Link to post Share on other sites
