samcolt45
In Need Of Some Advice Regarding A Classic Holster
I jut received a vintage NOS Brauer Brothers K32, which I'd searched for and wanted for quite a while.My only gripe with the holster's design is its course-grain Interior, which is murder on finishes.I'm considering coating the inside of it with gum tragacanth to smooth it out.Your thoughts would be appreciated.Bob
Thats what I do all the time. Slap sum Gum T on it and rub it in with a long dowel. Works great
mlapaglia
You've do this often with such vintage holsters as the one I described?
It's a common method to stick down fuzzies and smooth the interior of unlined holsters.
Should I need to burnish afterward?
mlapaglia
Yes, I do.
You should burnish the edges on everything you make, so, yes burnish afterwards.
If you are dying the inside of the holster...... dye first before the gum tragacanth as it will interfer with the dye if done before.
