Members shooter55 Posted March 19, 2013 Members Report Posted March 19, 2013 I have seen people wet the edges prior to edging, and others not. Normally, I do not wet before edging. Can I get some opinions as to if you do or don't and what benefit is to wetting verses not wetting. Quote
Chief31794 Posted March 19, 2013 Report Posted March 19, 2013 I wet before edging but I wet it lightly and let it dry back to nearly natural, if you try to edge when it is too wet, the edger can leave marks and the leather can bunch up. The other thing is to have a very sharp edger, I strop all my edgers before using them. Dry works well but I like the smoother cut I get from dampened leather. You're gonna get lots of answers, one will be consistent, sharp edger only!!! Chief Quote
Members Cyberthrasher Posted March 19, 2013 Members Report Posted March 19, 2013 I lightly moisten, especially on the flesh side. If I don't, the edger will always find a tough spot and jump off to stab the tip of my pinky!! Quote
Members artycpt Posted March 19, 2013 Members Report Posted March 19, 2013 For me it depends on the leather I am using. thinner leather I wet slightly as if I haven't sharpened my edger it helps keep a good clean edge cut. Some softer or thicking (better quality) leather edges just fine without wetting. Quote
Members billymac814 Posted March 20, 2013 Members Report Posted March 20, 2013 Depends on the leather too. If I don't have to I don't because it saves time but a lot of times when its not cutting well I dampen it a bit, it definitely helps cut easier. I use Wickett and Craig tooling leather and it always seems harder to cut than any others. Quote
Members shooter55 Posted March 22, 2013 Author Members Report Posted March 22, 2013 Thanks for the replies. I appreciate the input. Tim Quote
