Members carsonauto Posted May 20, 2013 Members Report Posted May 20, 2013 Thanks lightningad! Our website is actually www.lwleathers.com We have 4 types of stamps depending on embossing preference. 1. The standard $38 one uses a c-clamp for emboss. Please see the instructions here: www.dropbox.com/s/jo2i4vjgxymko6t/instruction.pdf 2. One is designed for use with arbor press ($68) Sometimes it can be hammered on too depends on the size of your design. https://www.etsy.com...or-arbor-press? 3. We have another one that comes with a hammering handle ($98). The stamps are interchangeable, perfect for multiple stamps (additional stamps are $38 each only) www.etsy.com/listing/118992398/custom-leather-stamp-with-hammering 4. We also provide a custom heat embosser for leather stamping ($128). Please see the video in the link below. It’s very easy to use and it takes only seconds to have a deep and long lasting emboss. www.youtube.com/watch?v=PNeDelNRqEU www.etsy.com/listing/98894284/custom-leather-stamp-with-heat-embosser So, the $38 stamp should not be used on an arbor press? Quote
Members lwleathers Posted May 20, 2013 Members Report Posted May 20, 2013 So, the $38 stamp should not be used on an arbor press? Hi there, the $38 one is only 8mm thick and we do not recommend using with an arbor press because after prolong usage, it tends to crook. We recommend the 25mm thick one for arbor press. Quote Cheers, Calvin www.lwleathers.com Custom Stamps - Heat Emboss - Branding Tools
Members carsonauto Posted May 20, 2013 Members Report Posted May 20, 2013 Hi there, the $38 one is only 8mm thick and we do not recommend using with an arbor press because after prolong usage, it tends to crook. We recommend the 25mm thick one for arbor press. Good to know. Thanks. Quote
Members tboyce58 Posted November 7, 2013 Members Report Posted November 7, 2013 I just got a stamp from lwleathers...they did good work! Quote
Members Studio-N Posted November 7, 2013 Members Report Posted November 7, 2013 (edited) you can check mine out at http://www.lasered-stamps.com Holiday special on them coming soon. Edited November 7, 2013 by Studio-N Quote "Out of my mind.....back in 5 minutes"
