Have you considered purchasing a workmate?
http://www.amazon.co...&tag=mozilla-20
I haven't considered a workmate. Are they sturdy enough and do they have enough mass to take the pounding without transferring the noise to the floor and the rest of the house? I know that a granite block put over a damping poundo sheet will absorb a lot of the noise but does the bent sheet metal and plastic workmate have enough mass to couple with the 12x12" granite block? What has been your experience with this setup? Thanks for your suggestion.
Mike
I bought a Bekvam Kitchen trolley from ikea for a similar purpose, I've got enough bench space in my work room but the room gets cold and the natural light is lacking in winter so it's great to be able to move it around for a more sunny spot. I carve standing up so it might not be exactly what you are after but it might give you an idea to start.
I just looked at the Bekvan Kitchen Cart on the Ikea website. http://www.ikea.com/us/en/catalog/products/30240348/ It looks pretty close to exactly what I was thinking of. I'm think I'm going to borrow their design concept and with cheap 2x4s and scrap plywood realize my own version. Thank you very much! Have you made modifications to it for your leatherwork bench or have you left it as is, and clear it of your tools and supplies to hide it in plain sight when not using it for leatherwork?
Mike, have you seen Nigel Armitage's log workstation? You could put it on casters.
I really like the
I really like the log workstation. I'll see if I can talk my tree trimmer out of a correct size piece of log with sufficient mass and strength. It may be easier than to build a bench out of 2x4s and plywood. It certainly looks more "organic."
Thanks
Edited by MJO
I just looked at the Bekvan Kitchen Cart on the Ikea website. http://www.ikea.com/...ducts/30240348/ It looks pretty close to exactly what I was thinking of. I'm think I'm going to borrow their design concept and with cheap 2x4s and scrap plywood realize my own version. Thank you very much! Have you made modifications to it for your leatherwork bench or have you left it as is, and clear it of your tools and supplies to hide it in plain sight when not using it for leatherwork?
Left it as is just put a rubber mat and small granite slab on it when in use, most of the stuff I carve is smallish so I can put a small wood block which holds my carving tools at the back. I keep my mallets on the shelves. When not in use I keep it in the walk in cupboard in my work room if I left it out my husband would probably try and claim it for the kitchen ha ha.
A log of the right size sounds great and maybe lay a piece of one inch thick HDPE on top for pounding on. You can move it around with a two-wheeler. Even a cheap two-wheeler will work. For tool mounting such as a crank splitter or manual clicker press, I like a two drawer file cabinet with a 3/4 thick piece of plywood on top. I bolt through the plywood and the top of the two drawer file cabinet with the head of the bolt being in the file cabinet so the draws will still work. I put large fender washers under the head of the bolt. Then you have a couple of drawers to store things in. I have used my Lucris press like this for about three years now. You can move these with a two-wheeler also. The old very heavy two drawer file cabinet works best and you can usually fine one for about 15 to 20 dollars. -- Tex
Tex-Shooter - Winner of the 2003and 2004 Summer Nationals Slingshot Tournament.
Too soon old/too late smart
“It is better to remain silent and thought a fool, than to open ones mouth and remove all doubt” Abraham Lincoln
My YouTube Channel ----- slingshotbill's channel - YouTube
