Hi Matt,
Since it's already a closed case, IMHO it should hold the ammo without the need for loops. Cutting, dyeing (potentially), installing, moulding loops will call for extra space in the case and by the look of it might easily amount to extra 30-60 minutes of work depending on loops design (I might be wrong here). Too fiddly if it can be replaced by something simple but just as effective.
Thanks for all your advice. I'll try which approach works best for me.
Cartridge loops would take more time than a block of foam, but would increase the appeal and overall quality of your case. And like many tasks, once you learn how to make cartridge loops it will become easier and less time consuming. Not in hurry I can sew 25 loops in an hour pulling that long piece of thread through. 5 to 8 loops would be relatively fast once you are accustomed to the process. Do some research on cartridge loop making, and give it a try, even if it doesn't get used in your project you will have a new skill that will make you money in future projects!
I think you're over thinking this. I'd take a piece of 10oz leather, double it up and punch 308 sized holes in it and cement it into the box pouch about 3/4" from the top of the pouch.
(actually, I'd do loops...but you mentioned this isn't your prefered option).
Another option is a grid insert.
Edited by MadMorbius
  • 4 weeks later...
  • 2 months later...
2X4 and some stain...
Mike,
HamanHide LeatherWorks
hamanhide@gmail.com
Heber Valley, Utah
