RG,
I forgot to mention that Fiebing's offers three classes of dyes: Leather Dye, Professional Oil Dye, and Institutional Leather Dye. I have used all three, all on the same project. Just have to be careful of the alcohol drying the leather out too much.
Catalog is out today!! I'm sure i can live with their leather Dye, or Pro Oil dye. The tandy store I frequent doesn't carry that many colors, and I miss Pro Dye's med. brown, saddle tan, and others.
Thanks again for your suggestion.
Rick
Rayban
www.rgleather.net
Rick,
Glad I could help. I also use Tandy Cova Dye as well as their new Eco-Flow Hi-Lite stains. I use them for different effects I am trying to accomplish. For example, when I did the Air Force Medal and Air Man insignia I needed something that looked like enamel finish so I used the Cova Dye. For the Native American Totems where I am trying to get the weathered natural look of the art form, I will use the Hi-Lite since it is more of a "wash" appearance. It will also make a good background color where I want to color the background but not the carving so that the carving standout and is not over shadowed by the coloring.
Bill B. Nead
Just dont get anything you used the eco on wet- ever. We tested these when they came out under various conditions and rated them "Not Finished Yet". They blend well, but again, dont accidently drop your wallet in the slush- :no:
I'll stick with the Fiebings dyes; as for color choice, we *used* to make our own... B)
- Alcove Leather & Crafts
"The Unique Leather Supply Store"
"Ask your supplier where their stuff comes from!"
You are correct on the water based dyes. I always go over my water based work with either satin finish or gloss finish to lock in the water base. I use two to three coats with the first two being put on by brush and the final being rubbed on. This usually does the job. When I use the oil or alcohol based dyes, I don't need a final sealer unless I want to make sure the dye does not rub off on the users clothes, then I will seal them as well. Nothing like having black dye rub off on white clothing.
Bill B. Nead
