Members DS STRAPS Posted August 5, 2014 Members Report Posted August 5, 2014 Looking at some watch straps and wondering how to roll leather edges and how to achieve this look Quote https://www.facebook.com/dswatchstraps
Members Nuttish Posted August 5, 2014 Members Report Posted August 5, 2014 Looking at some watch straps and wondering how to roll leather edges and how to achieve this look There are no rolled edges there. The top one is just painted. The keepers are folded and glued. What look do you mean? Quote
Members DavidL Posted August 5, 2014 Members Report Posted August 5, 2014 Sometimes they do roll the edge. When they do roll the edge they first roll it over, contact cement, then carefully use a dremel to thin the inside till its nearly there. Quote
Members DS STRAPS Posted August 5, 2014 Author Members Report Posted August 5, 2014 Here is another pic http://stonecreekstraps.com/data/storage/attachments/3a82df762aa61c5ee69cef306520148b.jpg Quote https://www.facebook.com/dswatchstraps
Members jimmy eng Posted August 6, 2014 Members Report Posted August 6, 2014 Need a photo of the back. It seems like it's the top piece is wrapped over the edge then a shorter back piece is glued on top then both are stitched together. Quote
Members DS STRAPS Posted August 6, 2014 Author Members Report Posted August 6, 2014 Need a photo of the back. It seems like it's the top piece is wrapped over the edge then a shorter back piece is glued on top then both are stitched together. After looking at a few more pics you are correct. Are the edges thinned down before wrapping and what tool might be used to thin it down, is there something other than a skiver? Quote https://www.facebook.com/dswatchstraps
Members DavidL Posted August 7, 2014 Members Report Posted August 7, 2014 hand skiver (skife, super skiver, japanese utility knife, book binders paring and a few others) , sandpaper, sanding drum attach. on a dremel, japanese wood working skiver. Best all around knife if I had to choose one would be japanese utility knife, it can cut perfectly straight lines without a ruler, cut curves, pull cut, push cut and used as a chisel for a perfect straight cut and skive edges. Only the first watch is wrapped (maybe) but the leather if thin enough .4mm 1 ounce doesnt need to be skived. Needs to be .4mm or at least .6mm it could be 1mm thick at the most. Youtube has a few good examples search around you will find out how to do it in a few minutes. Quote
Members DS STRAPS Posted August 7, 2014 Author Members Report Posted August 7, 2014 hand skiver (skife, super skiver, japanese utility knife, book binders paring and a few others) , sandpaper, sanding drum attach. on a dremel, japanese wood working skiver. Best all around knife if I had to choose one would be japanese utility knife, it can cut perfectly straight lines without a ruler, cut curves, pull cut, push cut and used as a chisel for a perfect straight cut and skive edges. Only the first watch is wrapped (maybe) but the leather if thin enough .4mm 1 ounce doesnt need to be skived. Needs to be .4mm or at least .6mm it could be 1mm thick at the most. Youtube has a few good examples search around you will find out how to do it in a few minutes. Thanks that helps a lot! Quote https://www.facebook.com/dswatchstraps
Members DavidL Posted August 7, 2014 Members Report Posted August 7, 2014 sure. Also forgot to mention with the japanese utility knife you can also use it to trim edges flush if you add a liner the hangs over. Quote
Members DS STRAPS Posted August 7, 2014 Author Members Report Posted August 7, 2014 sure. Also forgot to mention with the japanese utility knife you can also use it to trim edges flush if you add a liner the hangs over.Any certain brand and style preference you recommend? Quote https://www.facebook.com/dswatchstraps
