(I am buying my first pricking iron)
Here are some of the stiches per inch that I would like to replicate:
1eb53422_59910_461338664975_2817618_n.jp
And not SPI that look like:
And if I was using this SPI what size leather (mm/oz) would i be using?
7-8 spi. I use 7 as the standard. 9 is fine stitching for me.
It depends what you prefer personally, some like to go smaller than 9 others like 5 or 6 as standard.
What is the maximum oz/mm thickness of leather can I sew with 7 spi? (And 8 SPI ?)
I was hoping to make a bag that was 9-10oz thick.
I seem to like finer stiches as an an asthetic choice. To me it look alot less western/cowboy and more working-profesional.
Edited by leetpuma
I don't think the thickness is a big issue. Some people who stitch saddles go as thin as 14 SPI on thick leathers. 6-7 or 7-8 could still work. 5-6 you could still do but any lower is a bit thin, unless its meant to drape.
Id like to see what you come up with.
Good luck.
I don't think the thickness is a big issue. Some people who stitch saddles go as thin as 14 SPI on thick leathers. 6-7 or 7-8 could still work. 5-6 you could still do but any lower is a bit thin, unless its meant to drape. Id like to see what you come up with. Good luck.
Thank you very much!!!
I did not know that SPI was not a huge issue with reguards to structural integrity.
For somereason in my head i had this idea that i would shread the leather if I went too high SPI on a thick leather.
I have a few bags in mind that I will be making for fun.
I will start with smaller projects from the stolhman books and see how far i get.
I my final goal will be to make a briefcase like some of them posted here:
http://www.styleforum.net/t/34253/briefcase-porn-thread
Image gallery: http://www.styleforum.net/t/34253/lightbox/
Eventually i would like to build this bag:
With leather that I have stained to look like:
Edited by leetpuma
higher spi will be more delicate and can actually rip in some cases. Some people say to stitch the same mm as the thickness, say 4mm thick stitch 4mm wide, I don't think thats actually necessary and don't see a reason why 7 SPI can't be stitched on thick or thin leather.
7 spi or 9spi is okay structurally, but 10 and up can rip if the holes are too large or they are misplaced by a bit.
Edited by DavidL
