DavidL
Machine Washable Chrome Tan Or Dyed Leathers?
Anyone has experience with using dyed leather for garments that are machined washed?
Would the dye just bleed onto other fabrics? Can the dye be just pre washed before assembly so that all the excess dye is removed, locking the remanding dye from bleeding.
The only two I know that can be used safely is chamois leather and machine washable leathers from jean patches. Slow bark tanned leathers or home made leather made from natural dyes are also in my mind for some that won't bleed when machine washed.
Hi DavidL
Just saw your post. You might want to have a look at
http://www.spottedponytraders.com/info/leather.shtml?action=detail&id=LEDAE
I buy machine washable deer from them. I have not washed my leather dress yet but have handled pieces that other people have washed in the machine (no dryer!) and they seem fine. The hides are very nice and if you let them know your needs they will try to find you the right hides. They are very knowledgable and can probably give you good advice.
Cheers, Toolingaround
Il check the link Toolingaround, appreciate the response.
I did a bit more research and think most leathers jackets can be put through the washer without it bleeding dye. So maybe any type of leather that is pre washed before assembly won't bleed or regular sealed veg will work.
