I had one of these. I tried using it for mostly veg tan leather and found that it didn't really work very well. It would cut into the leather and I ruined a lot of pieces with it. The blades are razor blades so they are easy to replace. You could spend a few hundred more and get a used Chinese bell skiver and you would have a much better skiver. These things aren't cheap.
Andrew
For example. The scarf-fix is $379. I was able to buy a used consew bell knife skiver for $600. Definitely more money but works much much better.
Andrew
Thanks, I will check out the machine skivers.
Any difference between a well built chinese machine skiver vs a renamed chinese skiver sold in USA or Canada besides warranty?
Does any one know the difference of a bell skiver or round knife skiver, also the top and bottom feed differences?
If anyone has a review of a chinese bell skiver I would be interested.
There's no such thing as a round knife skiver as far as I know. Supposedly a German Fortuna skiver is better than a Chinese clone but I if you get it from a reputable place it should work well and be cheaper than a German machine. As for top and bottom skiver, they are better for heavy leathers but I feel they are less precise On the thin stuff. Much more expensive too. If you mainly need to go edge skiving rhen a bottom feed siding even for heavy leathers. If you need to do a fill two inch split on belt leather than you need a top and bottom feed.
Andrew
