roop
Paracord Mecate-How To?
Hey all,
I'm interested in trying my hand at braiding a paracord mecate. Ive searched around here and the net for a good tutorial/how to. I've found some info but not as in depth as I need. I have no problem with the braiding. It's basically the start and finish that I need help with. if anyone could help with some pictures of that it would be much appreciated.
thanks,
Jon
Just double the length of your strings and start braiding in the middle. Say you're going to use 35' per string to braid a 23-24' mecate, make each string 70' and loop in the middle over a nail or whatever in your vice and start braiding. The easiest is to find the middle on all your strings and tie together in a loop to keep straight. Then tie each in a tamale and wrap with a good rubber band. When you get that done, untie the loop and start. Make it good and tight at the start. When done just go back and unloop and put in a nice piece of leather for a popper. You can also do that at the start. The finished end just tie a turkshead. If it's a 12 strand rope, tie a 12 strand knot, then tie an 8 strand so it has a little taper, keeping all your ends out the end. If you've done any button work you could stay with just a 12 strand knot and leave your ends stick out and tie a pineapple knot over the tied knot.
