Frogwaterband
Covering A Piece With Clear Resin
Has anyone ever covered leather with clear resin? I made a license plate for a friend and I would like to protect it from the elements, and I'm thinking about encasing it in resin. Any thoughts on potential issues?
The title was supposed to say "Covering a piece with clear resin" not purse. Ha
The title was supposed to say "Covering a piece with clear resin" not purse. Ha! Auto correct
Fixed it for you!
Edited by northmount
I have covered a leather patch with clear resin in the past. The piece must be thouroughly sealed or the resin will seep in and discolor the leather. I sealed and glued a leather patch to a plastic, recessed cover. I used super glue for the bond, leveled the piece and poured the resin over it. It works as long as the leather is completely sealed.
Do you think that a few coats of the "super shene" from Tandy would seal it well enough to keep the resin from penetrating?
I use resolene mix 50/50 with water. I had to use 3 good coats to get a good seal, and I allowed 24 hours drying between coats. I would do a test piece with the Super Sheen before I tried to cover the actual piece.
