Mockingbird
Fileteuse M6000 Regad Machine
Its the replacment for the G6M from Regad which Im told is out of production. I havent seen one in the flesh as yet but have one on the way for testing
M6000 is model that combined two of M3000 model.
M6000 is economic version of G6/M.
G6/M had a issue with countries with voltage of 220~230V , 50~60Hz
so they made G6000 to solve it.
G6/M will not be discountinued. : )
here is detailed spec of the model.
M6000 device
230V-240V 50/60Hz
2 LV outputs with 0V to 20V electronic
controller
6A 120VA (delivered without any handle)
Detailed description
Metallic box apparatus
Dimensions : 215 mm x 185 mm x 80 mm
Weight : 4 Kg 200
One "On - Off" switch
One indicator light on each LV
The 2 green indicators light on step 1
2 LV outputs with 0V - 20 V electronic controller
Removable power supply flex
The M6000 device permits the use of two tools connected simultaneously
Safety instructions
Only use this transformer with the electrical tools recommended by the supplier
Do not use this transformer for any other purpose.
This transformer is designed for use indoors and in dry conditions only.
While the transformer is on operation, the tool is hot. Be careful for the handling.
When you stop working do not put the handle with the tool in contact with objects.
Instructions for use
· Preparing the unit for use
- connect handle to low voltage apparatus output
- connect transformer to mains supply
- switch on by pressing the switch button on-off on the front
· Switching off the unit and changing the tool
- cut off the power supply using the switch button on-off on the front
- make sure the tool is cold before unscrewing it
- then screw on an other tool
· Transformer safety mode
- apparatus with low voltage 20V safety transformer
- protected against secondary short circuits
- in the event of malfunction of the holder or the removable heated tool, the transformer will
switch to safety mode
Switch off the device and when it has cooled down replace the defective handle or tool
Then press the button on-off on the front to switch the unit on again
Edited by leathertoolz
Hi,
I have recently been in contact with ETS Regad & fils and can confirm that the G6/M unit is discontinued and has been replaced by the M6000.
From what I've been told, the M6000 unit is of simpler conception, which makes it more affordable, while retaining the same characteristics as the G6/M.
Cheers!
Thanks for the info guys.
DavidL: The digital display one looks interesting!
http://www.adece.eu/gb/tools.html
Anyone have info/experience with these?
They're offering two head units. One without "power regulation" — I read this to mean it doesn't regulate temperature, just the frequency with which it sends line current to the cartridge heater with something like a pulsating on/off switch. The other has "power regulation" — as it has a digital display, I believe this one has a PID in it with a thermocouple in the handle. These will maintain temp pretty accurately, but I don't think accuracy really matters all that much as long as you're in the ballpark. These machines are stupidly overbuilt. No wonder they cost a fortune.
