Members Tallbald Posted August 12, 2015 Author Members Report Posted August 12, 2015 Thank you all. Johnv474 I shall let my belts dry several days in warm weather before using Resolene. Don. Quote
mlapaglia Posted August 12, 2015 Report Posted August 12, 2015 Thank you all. Johnv474 I shall let my belts dry several days in warm weather before using Resolene. Don. As long as you apply the oil lightly letting it sit over night is more than enough. The oil does not really dry, it distributes through the leather and spreads out. You can let it sit several days but after the first 12-24 hours it will be fine to apply the resolene. I work in the evenings so if I oil before I quite for the night it sits about 18 hours until I can get back to it. I have never had a problem applying the Resolene after that. To be honest, on a rush job I applied the resolene after 4 hours but I do not like pushing my like unless I have to. FYI resolene works best when cut 50/50 with water. It helps prevent bubbles from drying in the finish. Michael Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members Tallbald Posted August 15, 2015 Author Members Report Posted August 15, 2015 Thank you again Michael. Don. Quote
