westcoasters
Schaefer Cementer Machines (EC Series) for sale
Hello all, I have two refurbished Schaefer Cementers. They are the edge coating series. I have an 11'' and an 8'' for sale.
11'' cementer - $1000
8'' cementer - $800
buyer covers shipping, but willing to negotiate
These machines do not have a heating element!
Edge Coating Machine (model EC): The EC model is an edge gluer, which is a gluing machine designed for adhesive application along the edge of a part. This type of gluing machine has open end (cantilevered) rollers that allow adhesive application to either the edge of a sheet or to the full surface (up to the width of the gluing machine).
Home
Adhesives
Adhesive Wax
Hot Melt HM
HRC Hot Melt Gluer New
Label Cementers
Sheet Cementers
Smoothing Press
Solvent Cementer
Topside Coaters
Adhesive Recirculation Systems
Custom Machine Design
Nip Rolls
MSDS
What's New Widths, 3", 8", 11", 15" The adhesive coating thickness is adjusted by means of a dial which controls the gap between the pickup roller that sits in the glue tank and the coating application roller.
The standard machine can glue parts from paper thickness to ¼ thick, but an optional model with floating feed roll can be used for adhesive application to parts up to 2" thick.
The position of the feedtable relative to the coating roller is adjustable so the machine can be set for gluing a narrow strip along the edge of a part or can be used for adhesive coating of the full surface. The edge cementing machine can be built with special rollers for coating stripe patterns or for application of a stripe of adhesive a pre-set distance from the edge of the part.
The Edge Coater can be used for the application of many types of adhesives - latex cement, dextrine glue, PVA and EVA resin cement, acrylic PSA adhesive, epoxy adhesive, ultraviolet cured adhesive, hot animal glue (heated glue tank), and many other types of coating and adhesive formulations. The machine is designed for easy cleanup, and has a removable glue tank and adhesive pickup roller. This design allows glue to be cleaned from the machine in less than ten minutes.
Edge Coating machines are very popular for the application of latex cement to leather goods such as wallets, handbags and belts, as well as to shoe and boot components. These machines are also used for gluing many other products where a band of adhesive is needed: calendars, easel backs, sample books, specialty boxes, filters and toys are just a few of the other applications for these machines.
Edited by westcoasters
I've found the marketplace and have set a post there. Apologies for the screw up, couldn't find a way to delete.
