Question for folks that own Harbor Freight's 1 Ton Arbor Press: What is the distance between the bottom of the ram (not sure if this is the right word) and the top of the slotted steel plate? How tall is the steel plate? I'm interested in trying this with some taller stamps and I'm trying to figure out if there's enough room.
Thanks!
From the top of the slotted plate to the part which holds the ram (the ram can go higher) is 4 3/4 inches. The plate is roughly 5/8in thick, not including the pin on the bottom that holds it in place.
If you drill a hole deep enough in the ram, tool length shouldn't be much of a problem, unless it's a really long tool.
