Thank you very much. I don't know how I missed seeing that second hole. The screw did work and now my adjustment is about in the middle. There are days I think I will go nuts before I work out all the issues on this machine. The good news is I am learning a lot as I go.
When I went to go put the needle plate back on I notice that the finger of the bobbin lever was striking it and causing a jam. The only thing I saw that would solve that problem was to remove the small section of the needle plate where it was hitting and everything appears to be working now.
