13 hours ago, baroness said:
For the problem of one card not registering even though it is the correct side of the wallet being tapped, does it change it you turn the card over in the wallet? Instead of having them all go the same way, have that one facing the other way?  Could it be 'backwards'.  Not sure if the signal could be ricocheting/reflecting off the foil and causing problems with the reader.  On't know enough about the signal the reader send out.
Yeah, I tried having the card flipped around in the slot, but it still fails to read. The weird thing is that when I try to tap my card, the reader doesn't give an error like it's getting confusing signals; it just doesn't register anything at all.
On 3.5.2018 at 8:30 PM, fredk said:
No, its real thin aluminium tape for use on heating pipes etcetera. Its only 0.06mm thick. It doesn't take much to interfere with the RID signal
https://www.ebay.co.uk/itm/Aluminium-Foil-Tape-Rolls2-48mm-X-45m-Heat-Insulation-Duct-Self-Adhesive-Silver-/263110117156?var=&hash=item0
Thanks for the tip, I will give that a try if there's something similar available here (which I assume).
