Forlornvanity
Consew skiving issues
Hey ya'll. I'm slowly losing my mind with my bell skiver so I figured I'd try my hand here. I tried searching around a bit but hadn't seen anything pertaining to my issue.
I have some 6/7oz leather I'm looking to skive down and for some reason I can't get it to properly feed through. I keep messing with the adjustments but the roller doesn't seem to have enough tension on the leather to actually push it through. It just rolls underneath it. This is the first time I've tried using a leather this thick so maybe I need to do something different than usual? I've adjusted the presser foot and still no luck. (I currently have a 2" pressure foot on.) Then, I blew the fuse. I don't really see the correlation between the fuse and my roller issue. I don't actually know what would cause the fuse to blow to begin with.
Any help/direction would be amazing. I'm using a Consew DCS-S4.
