Id look at Mcmaster Carr and see what they have.  You might also be able to use a urethane roller.  Once you get a new roller, dont leave it under pressure when your not using the machine.
Some urethane, I believe, can be machined.  Rubber can be ground or sanded.
I had a rubber puller roller that had a flatspot.  I put the roller in a drill press then used a sander to make it round.
Ive heard of rubber being turned in a lathe after freezing it.  But Ive never done that.
  • 2 weeks later...
