Hi All !
I am interested in picking up a CONSEW double need walking foot machine. Most of the work I will be doing is single needle, but I would like the option to do French seams now and then. Can a double needle machine be used efficiently as a single needle setup to do cording, etc...? Will common cording presser feet work or do they make special ones for double needle setups? Is it best to stick with a single needle machine?
Any advice is much appreciated!
Thank you,
  Mike
