  • entries
    28
  • comment
    1
  • views
    12,433
Are You Master the Basic Info of the Fortnite Old Smokey
Fortnite Old Smokey, a Legendary Scavenger Weapon in Save the World and uses Shells 'n' Slugs. This shotgun can deal heavy damage and knockback to multiple enemies within a very wide cone. Has really restricted range, tiny ammo capacity, and a long reload time. Though reduced durability, a great deal less costly to craft. You may need 12 Planks, 21 Mineral Powder, 1 Active Powercell, 8 Ore to craft it. Keep an eye here and we'll keep updating the Fortnite Weapons Guides.
Keep in mind that Old Smokey also has the other version:
Scavenger Double-Barrel Shotgun is the Epic version of this weapon.
Basic Info
Name Value
Damage 113
Crit Chance 10%
Crit Damage +50%
Fire Rate 3
Magazine Size 2
Range 768
Durability 300
Durability per Use 0.69
Reload Time 3.5
Ammo Type Ammo: Shells 'n' Slugs
Ammo Cost 1
Impact 900
Trait Synergies
Name Class Description
Adjustable Choke Soldier Increases critical rating with shotguns by 8/13/18.
Advanced Tactics Soldier Ranged weapon damage increased by 10%. Health increased by 10%.
Critical Blast Soldier Increases shotgun critical hit damage by 70%.
Debilitating Shots Soldier Dealing ranged damage applies one stack of Vulnerability, increasing damage taken from all sources by 5% on the target for 15 seconds. Stacks up to 3 times.
Enduring Machine Constructor Your weapon takes 60% less durability damage while on BASE.
Explosive Rounds Soldier Killing 10 enemies with a ranged weapon deals X damage in a 1 tile radius.
Eye on the Prize Outlander Every 15 headshot kills grants 1 Charge Fragment.
Fragment Generation Outlander Every 60 kills grant 1 Charge Fragment.
Grenade Generation Soldier Every 30 kills with a ranged weapon grants 1 Frag Grenade. Count resets after 15 seconds without a kill.
I Love to Reload! Soldier Reloading the equipped weapon increases run speed by 30% for 3 seconds.
Improved Headshots Soldier Increases headshot damage multipler of ranged weapons by 13%/20%/27%.
In a Pinch Soldier Increases weapon reload speed by 35% if the magazine is empty.
Locked and Reloaded Soldier After reloading, rate of fire is increased by 25% for 5 seconds.
Make It Rain Soldier Headshotting enemies increases ranged weapon rate of fire by 25% for 5 seconds.
Precision Handling Outlander Hitting a headshot increases the speed of your next reload by 7%. Max 35%. Resets after reloading.
Pump It Up Outlander Increases shotgun rate of fire by 35%.
Quick Clip Soldier Increases reload speed by 30%.
Shell Shock Soldier Increases shotgun damage by 24%.
Start Up Soldier Firing with a ranged weapon increases rate of fire by 1.2% per shot for up to 20 shots. Resets on reload or weapon switch.
Steady Aim Soldier Reduces recoil by 29%.
Survivalist Soldier Killing an enemy with an ability or weapon recovers 5 base health per second over 3 seconds. Kills reset the healing duration. Will not activate on full health.
There Are Many Like It... Soldier Your weapon takes 45% less durability damage while affected by War Cry.
War Cry Soldier Give a War Cry, affecting friendly characters within 4 tiles for 10 seconds. Grants 45% more damage and 30% attack speed for ranged weapons and 45% more damage and 20% attack speed for melee weapons.
Waste Not Want Not Soldier Increases ammo capacity of all weapons by 40%.
Availability
Old Smokey was readily available as featured loot in Scavenger Choice Llamas purchased in the Vindertech Store through the Horde Bash event.
Pros and Cons
Pros:
Can deal heavy damage and knockback.
Cheap to craft.
Cons:
Restricted range.
Tiny ammo capacity.
long reload time.
Low durability.
Vs Other Weapons
Old Smokey vs Dragoon
Old Smokey and Dragoon, they may be each basically precisely the same gun but the stats are distinct. which a single you need to choose and level up?
The Dragoon has lately been glorified right here as a transportable wall launcher. And it kind of serves the objective since it has the wonderful impact, but only at point blank range, the harm fall of is serious, even at a very close range.
Old Smokey is for clearing groups up close, and it might clear a bunch of husks at a higher distance (talking half a tile, a tile at most)
Dragoon for smasher stagger/knockback at point blank, Old Smokey for clearing up groups of trash mobs up close. Also, the Dragoon fires both shells at once, Old Smokey provides you two shots before reloading.
Old Smokey vs Thunderbolt
Thunderbolt is a Legendary Break Action Shotgun and makes use of Shells 'n' Slugs. Offers heavy damage and knockback to multiple enemies inside an incredibly wide cone. Has an exceptionally limited range, tiny ammo capacity, and an extended reload time.
Actually, the same weapon stats sensible. The only difference is definitely the durability. By literally I mean it has the precise identical stats. Just choose which one looks cooler tbh.
0 Comments
You are posting as a guest. If you have an account, sign in now to post with your account.
