  • entries
    28
  • comment
    1
  • views
    12,432
Fortnite Gets New Scoped Revolver and Glider Redeploy Item in V7.20 Patch
fortnite-patch-v720-scoped-revolver-and-
Now Fortnite's first big patch of the year has been revealed by Epic Games. Patch v7.20 adds a few new features, including a new Scoped Revolver, the return of Glider Redeployment within the kind of a consumable item, a brand new One Shot LTM plus the usual slew of stat tweaks, rebalances and also the like.
New Scoped Revolver
The Scoped Revolver is essentially the Six Shooter but kitted out having a scope which permits for heightened accuracy at extended range. It's accessible in Epic and Legendary variants, fires Medium Ammo, and it packs a punch with 42/44 harm per shot.
Where are you able to uncover the Scoped Revolve though? It is treated like each other weapon in the game, and so could be identified within the following locations:
  • Chests
  • Supply Drops
  • Vending Machines
  • From the floor around dead players
So, your best bet for locating a Scoped Revolver is likely to hit the chests difficult and hope for any tiny luck. Preserve a keen eye out for the loot around fallen players as well, just in case they've been luckier than you in their hunt for the new gun.
By the way, if you also want others in-game weapons, you can buy fortnite save the world weapons on U4GM where you can purchase items that you wish to without any delays or risks involved.
Glider redeploy as an item
Glider Redeployment has returned, but within the type of actual Gliders identified across Fortnite's map. Pick one up, and they'll take up an inventory slot, so if you're ever facing a cliff and will need to produce a fast getaway, all you've to perform is press your jump button in mid-air to whip it out.
Glider's come with a generous ten charges, so you can float around the map no less than ten times ahead of it'll disappear. Oh, and also you won't consume a charge when using things just like the Launch Pad and Rifts-to-Go, which is nice.
A New LTM - One Shot
If you're worried that will not offer you adequate opportunities to soar, the new LTM has you covered. One Shot lowers the gravity; players only have 50 health, bandages would be the only healing item and sniper rifles will be the only weapon. I do not anticipate I'll have a great deal achievement, as I'm not incredibly precise even when I'm around the ground, but I can't get sufficient of low gravity modes.
What Are the Other Updates in Fortnite Patch 7.20
The update also includes loads of weapon tweaks, like miniguns and sniper rifles, and it is now easier to modify direction when applying the zipline. You will discover bug fixes galore, as well.
A new arctic island, Frosty Fortress, has appeared in Creative mode, together with some buildings currently places. There's a brand new nation theme, too, filled with farmstead prefabs. Save the World, meanwhile, includes a new challenge, rewards, and heroes. For a examine each addition in this patch, ensure that you head over to the official weblog post.
0 Comments
You are posting as a guest. If you have an account, sign in now to post with your account.
