Members rscow Posted March 5, 2011 Members Report Posted March 5, 2011 Hi, first post. I'm making a rawhide maul. I am building it over a 1/2" carriage bolt. I have made a handle from stacked leather disks. I have collected some heavy stuff for additional weight in the head. Not to heavy, I hope. I have procured a bunch of dog rawhide chews, soaked them, dried on a frame. Cut out a big stack of 3 inch disks. Dry, they compress down to about 3 inches. That should be good for what I have in mind. So, I need to assemble these disks into a blank, shape it up and drill out for the carriage bolt. What is the best way to secure these disks? Should I glue them? If I glue, with what? Epoxy, gorilla, carpenters? All the commercial ones I've seen disassembled and the head was a separate chunk. Not a stack of loose disks, so I assume I need to glue them. ANy experienced maul builders out there with suggestions? Thanks. Feel free to email if you prefer: rdscowjrATfastmailDOTfm RDS Quote
Members steve hansl Posted March 5, 2011 Members Report Posted March 5, 2011 If it was mine I would use a rubber based glue(Barge cement etc.)and double coat each piece and go from there. Quote
Contributing Member BillB Posted March 5, 2011 Contributing Member Report Posted March 5, 2011 RDS, A few weeks ago I answered a similar question in another thread and posted a series of pictures showing how my Al Stohlman maul is constructed. The leather discs of the head are held together by pressure only, no glue). If you glue them they will not have the flexibility that a non-glued maul has. In the end it is still your choice on how you do it. Here are the pictures I posted before. BillB Quote Bill B. Nead
BearMan Posted March 6, 2011 Report Posted March 6, 2011 Hi Bill & RDS, Please let me know how those proceedures work out. The way I was taught, by a person that made the rawhide heads on a regular basis, take quite a bit of time. I've made a few myself. My understanding was that if the disks were just stacked up dry, & then clamped,,, the head wouldn't be as hard as it is when done using the "wet" method. Here is the proceedure. The disks are soaked in slightly warm water until pliable, then the center hole is punched, & the disks are stacked on a mandrel. The mandrel is usually a stainless bolt that is the same size as the center shaft of the maul. Keep in mind that the hole will shrink slightly, making it VERY tight on the mandrel. The best mandrel is one that has an un-threaded section, about the same length as the thickness of the stacked head. Make sure you have some very large heavy washers both top & bottom, to apply pressure when you tighten down the rawhide disks. Keep in mind that something should be between the washers, & the rawhide, to keep from staining the rawhide. I just used some 1/2" exterior plywood, a little bigger than the rawhide. Once all the damp disks are stacked up, put the mandrel with the loose disks back in the warm water, to make sure all the disks are at the same saturation. About 10-15min. Next, mount the head of the mandrel in a vice, install the heavy washers on the nut end, with the nut,,, & tighten! Now, about every hour,,, re-tighten. You will need to do this, throughout the day,,, & maybe some more tomorrow. Once it gets to where it's staying tight,,, let it sit for about two weeks. It will take at least that long to dry! Try to make sure there is always some good air moving over it. Once it's dry, remove the nut & washer carefully, so that You don't loosen the disks. While it's still on the mandrel, apply a couple clamps, leaving room enough room so that you can drill a couple small holes, a little bit smaller than the nails you'll drive in about 3/4 the thickness of the head. Carefully drive it off of the mandrel, while still in the clamps & re-drill the center hole to the size of your maul shaft. Now, carefully remove the clamps, & drill & nail from that end, so that the head is solid, & won't fall apart. Now, drill & add a few more nails. You should now have something that looks like a rawhide head. It's NOT ready yet! Re-install the washers & clamps,,without the bolt,,, & let it dry for another week, so that the head dries from the center hole in. Now, as long as it feels dry, it's ready to shape & sand to the outside diameter. Once it's sanded, apply some thinned down shellac, a couple good coats, both inside & out. Once dry,,, it's ready. It's not quick,,, but it works. I hope this helps.... Ed Quote Ed the"BearMan" polarb1717@aol.com Beary: BearMauls@yahoo.com http://tinyurl.com/BearMauls "The Best tooling mauls available today!"
Members rscow Posted March 6, 2011 Author Members Report Posted March 6, 2011 Awesome reply. Thanks. Time is definitely required to dry these disks. I will go back through your post, and make sure I've got it right. Then get working. No wonder they cost so much. Roger Quote
Members rscow Posted March 6, 2011 Author Members Report Posted March 6, 2011 Awesome reply. Thanks. Time is definitely required to dry these disks. I will go back through your post, and make sure I've got it right. Then get working. No wonder they cost so much. Foolishly, I tried gluing the disks together. I used some Titebond. However, they didn't really stick very well. So I took them all apart. Using dog chews probably wasn't the best idea in the world. Or at least I should have used thicker ones. The ones I have look like a bunch of Pringles potato chips. But flat, at least. So, I separated them all out and soaked them a little and put them over a 1/2" mandrel. Added some plywood backers and a couple of fender washers at each end, then nuts. I have been tightening the mess down periodically all day. I get a turn or so every hour. In other words, following your directions. Once I have squeezed them as much as I can, I will take the whole assembly and hang it somewhere and leave it alone for a couple of weeks. Now, question: What kind/size of nails do you use? Finishing? Common flat headed ones? Do you put a ring around the whole end? How many would you suggest for a block that should end up about three inches long and three inches in diameter? Off topic, but I was stationed at the Naval Hospital in Beaufort for a few years (from 1998 to 2001). We loved that town. I hope it is still as great as it was back then. Thanks for your advice. Roger Quote
Members rscow Posted March 19, 2011 Author Members Report Posted March 19, 2011 Here is the end product. Thanks for all the feedback and help! Roger Quote
Contributing Member BillB Posted March 19, 2011 Contributing Member Report Posted March 19, 2011 It looks really good. Be careful, folks will want you to go into business making them. BillB Quote Bill B. Nead
Members Glock21 Posted March 19, 2011 Members Report Posted March 19, 2011 So reading your post I never saw what type of nails you used or how many? Here is the end product. Thanks for all the feedback and help! Roger Also how do you cut your circles out? A hole saw larger than what you need then sand it down to your final size? Here is the end product. Thanks for all the feedback and help! Roger Quote
Members rscow Posted March 21, 2011 Author Members Report Posted March 21, 2011 I just used some common nails about the same length as the block of rawhide. The heads show, but I don't care. Finish nails would probably have looked better... I marked the circles with a sharpy, and cut them out with some kitchen shears. When done, I sanded them on the belt sander. RDS So reading your post I never saw what type of nails you used or how many? Also how do you cut your circles out? A hole saw larger than what you need then sand it down to your final size? Quote
