Content Count
58 -
Posts posted by dmr400
Not a whole lot of leather on this, but thought it might stir some memories or good stories. I used a bedroll similar to this growing up around ranches in Eastern Oregon as a kid, and since I am going to spend this summer on the desert and in the woods as much as possible (missed the last 2 summers, government sponsored trip to Iraq) I decided it was time to make myself one. They aren't made to be light, historically using at least 5 or 6 blankets or quilts(usually 2 to 1: 2 below you for every one on top since you lose more heat into the ground). I went a little more modern, with 2 foam pads and 2 flannel sleeping bags, even though I usually only use one. The extra bag makes good padding, and nice to have just in case it gets really cold, which it can do in a heartbeat in the high desert. In the old days this was a buckaroos home on the range, with extra clothes, tools, weapons, even cooking gear rolled up inside it with his sleeping gear. The top is left long enough that when it rains you can just pull it over your head (if you didn't know, these are seldom used in tents, they work best under a starry desert sky! )
I incorporated a couple of changes that I thought would be nice into this one.
1.) Clips that will anchor the storm flap down, so you can leave your camp without weighting down the storm flap if you think it might rain or be dusty.
2.) The storm flap is actually a large pocket (left the top twice as long as actually needed, made a quick hem at the top, folded it over, and sewed down the edges), so you can throw your pants, jacket, phone, etc inside it to keep the dew off of them after you go to bed. You can also pack your clothes in it, saves a duffel bag.
These covers are nice because you can do lots of things with them. Add or subtract sleeping bags based on the weather (or even make them up with sheets and blankets like my dad did). You don't need as good a sleeping bag either, since you gain insulation from the canvas and the cover keeps water out, so you don't have to invest in a waterproof sleeping bag. I actually prefer the less expensive flannel lined bags. The cover also takes all the abuse and dirt, so even the cheaper sleeping bags last forever. Anyway, here it is. Anyone else use one, make them, have good memories they would like to share?
Oh, even though the last picture shows it open completely (so people can see how simple it is), I usually just loosen the cross ties to the last hole (even open the top one completely if its warm and dry) and crawl in bed, no reason to let the dew or creepy crawlies in. There is a third cross tie not visible under the storm flap at the top about where your chin would go. It's best to unroll and open during the day if you can though, just to let the moisture from your perspiration or breath dry out.
Neat holster, I like the lace up front as well.
Thanks Boomstick, I thought it would work out like that. By the way, your avatar isn't showing up for me, not sure if it's just me or a real error. Thought you might like to know.
Thanks Monica, apparently we were posting at the same time.
Hello,
I'm curious what everyone does for carriers for Glock Magazines. For example, and the reason for the question, a Model 19 and a Model 23 are the same exterior dimensions, and thus you can use the same mold. Do you feel/does your experience show the same holds true for magazines/magazine carriers? Or do you use separate dummies? How does this apply to the Glock model sizes, ie the 17/22, 20/21, 26/27, etc? Interested in what others do. Thanks, Andy
I use Adobe Illustrator for my patterns. Here is my process, hope it will help:
1.) Take a belly scrap and make a quick envelope style pouch with a couple inches of space around everything, throw a few lines of 3-4 stitches at intervals around the flap to hold it together. Wet mold around the dummy with the sight track dowl in place, and then take a pen and draw where the outside mold lines and key features (ejection port, cylinder, magazine release, etc depending on the gun) are. Also a reasonably straight line down the top where the site track/center of the fold is.
2.) Remove the dummy and cut the stitches. Use a rolling pin to flatten out the pattern. Scan into my computer (300 ppi, same as my documents in Illustrator so I don't lose or gain any size).
3.) Now that it's in the computer I place it into an illustrator document and "trace" for lack of a better word the outlines on a new layer. Add an appropriate gap for the stitchlines, draw the cutlines outside of those, and go from there. I use the rulers and guides EXTENSIVELY to get the spacing right, and for envelope styles I copy one whole side, paste it into a new layer, and use the reflect tool to make sure everything matches up. Or, I'll just draw half the pattern, trace it onto the leather, then flip it and draw the other half from the backside.
4.) Print the pattern on regular paper, and treat it as a disposable pattern (I've still got everything saved on my computer). No cardboard at all.
If I have made a mistake and given myself too much/too little room I can measure the error, use the rulers and guides tools in the program, and move whatever line I need to move almost exactly the right amount. Usually the second one is close to perfect, at least as far as layout goes.
I guess to answer your original question a little better, I don't use the stretch tools much. I draw each segment separately with the straight and arc line segment tools, so each corner or straight line is a different segment and can be resized independently.
I've attached a PDF of what it looks like after the mold/scan/trace process.
Thanks everyone for your time and feedback. I've ditched the rollover pictures for now, I work on a 21" monitor and sometimes forget not everyone is so fortunate Still debating on how to make that work, some experimentation is ahead. Have also shortened the wait time page as suggested, and changed the wording for the packages.
The Ayes have it...phone number comes off Thanks everyone!
Hello everyone, I'm just about finished with my website and I was wondering if anyone would mind crawling through it and critiquing it. It can be found at:
or if the link doesn't work at:
www.pfgunleather.com
I've only tested it in Internet Explorer and Mozilla Firefox, so if you use a different browser I would appreciate your feedback on how it worked.
The most glaring things missing right now are the examples of the different colors (which will be fixed in the near future), and the lack of a picture of the pancake holster (I keep forgetting to take pictures before I send them to their new home so I'll have to make another one of my latest design).
All comments and feedback gratefully accepted now matter how big or small! Thanks,
Andy
Dwight, I think he was wanting to sew so he could forgo the rivets, an idea that also occured to me. Personally, I just don't like the looks of them. If I could think of a way to sew belt ends and still be able to change the buckle I'd toss all my chicago screws too, but I think those are a necessary evil Anyway, I think it would look pretty neat with a sewn arrowhead style ending on the back, with just the stitching showing through the front (Not punching an extra hole and bringing the strap to the front of the belt). What do you guys think?
Holy Batman, it's an envelope! I missed that the first time too, slick idea...bet it's a pain to sew though! Although....maybe not so bad now that I look at it...easier than a VMII style since you don't have to fight the wings?
No problem ,here ya go. 4" long x 1.080" wide x .460" thick .Dave
Thanks DC!
Does anyone happen to have the dimensions of an older style leatherman tool, like the one attached? I'd like to whip up a case for my dad's for fathers day to match the belt I'm making him, but I can't find mine (too many moves!) and can't find the dimensions to make a model. Any help would be appreciated! Thanks,
Andy
Agreed that the pistol has some wiggle room as the trigger guard leaves the leather. Personally, I like to rock my pistol backwards as that happens when drawing for time, and the full length sight track ensures there isn't any of the infamous fuzz as the slide keeps the top of the sight from digging in as it pivots. But I have to say, the more I look at this holster the more I like the color scheme. I've been doing some white thread on black leather lately, and I just really like the contrast. Great minds, eh?
I like your makers mark too, very calligraphic. Almost reminds me of Arabic script, but I've had that on the brain for a while
Particle,
I really like that holster! Tooling looks good, and the black appeals to me. Have to say though, I'm with the customer, the ejection port kinda ruins the top line of the pistol. Question, how far back from the front sight does your dowel for the sight track go? I like to take mine all the way out of the holster, that way you can mold the port and still have a top line that continues the entire length of the piece, without a sight track that tapers down as you pull the pistol further out of the holster. If this doesn't make sense let me know and I'll try and explain what I mean better.
Will,
I was the designated "cat herder" for the section. Since I'd worked in recruiting before I was the most experienced junior NCO below the PACSUP with paperwork and administration (we had a pretty green section, none of us had worked personnel before this deployment, including the S1 actual so we learned a lot together!) so I got the big/long term projects and didn't have to work much on the day to day stuff. Finance/Pay issues, Promotions/Reductions, and Awards. We had a reinforced taskforce, 900 or so soldiers so I kept pretty busy And you're right...I ate a lot of crow Well truth be told, actually closer to a pterodactl in size if not texture
Hmmm...you're more of a betting man than I am I wonder what I would do in that situation, I'm not sure I'd not put a retention device on. Craftsmanship looks very nice to me though. Guy must be a better loader than I am a shooter, 3 mags plus one in the gun! Minimum 28 rounds assuming it's not an officers model...he's serious
DMR, . . . here is a pic of the one I made for myself, especially to carry an all steel full size 1911, 24/7 or thereabouts, with 1 or 2 mags.
It is two layers of thick 5/6 (much closer to 6 than 5), contact cemented together, neatsfoot oiled, dyed, sewn together, and the billets are 7/8 leather. The 7/8 is a bit overkill, . . . but my other one that I used for a pattern was only 38 years old, was a full 6 oz and it had stretched some I didn't want that happening again..
I used a Tandy buckle package, and love it.
Since I started wearing double layer belts several years ago, . . . that is my standard now, . . . love em.
If you are interested, there are a couple more tricks I use, . . .
May God bless,
Dwight
Dwight, that's a good looking rig! And the buckle set is sure appropriate for your interests I'd certainly be interested in hearing about your tricks, I have lots to learn. I wear a double layer belt now (ordered this one from A&G Gunleather, member here) since I didn't have my shop set up yet, thought I'd try the ranger style to see if I liked it. Looks fun to make too.
Max,
I found that link during my searches, but it's more an "Imitation" ranger belt lol, a full ranger belt isn't tapered and has an extra billet sewn on both ends, one for the billet and one for the buckle to attach to, with the buckle *usually* being the same width as the belt blank or narrower. Tough to describe, but easy to picture once you've seen one.
Hello everyone, I'd like to make myself a ranger belt to try the style out, and I have some questions.
1.) First, anyone have a good resource/how to link? I understand the basic concept, but I'd like to see someone else make one so I don't make any obvious mistakes.
2.) Do you prefer to make a 2 layer lined or single layer of heavier leather? I'm of two minds, on one hand I really like the look of the "Urban" Ranger Belt at http://leatherworker...topic=1911&st=0 with the creaser groves around the outside with no stitching, but I wonder if a single layer will stretch (I'm carrying a glock 19 everyday until my 1911 commander arrives). What weights do you use for either style?
3.) Are you using 1" or 3/4" buckles? Pictures always appreciated. I don't think I'll use a buckle set (I grew up on a ranch, but don't dress the western part too much anymore ) so it will have 3 leather keepers with creaser grooves.
I'd like to keep the whole rig kind of "understated" I guess would be the word. Buckles will be antique finish to avoid glare, etc. Also don't want it to SCREAM "gunbelt", though that's kinda tough with this style.
Any advice, suggestions, or pictures (front and back?) of one you've made? Thanks everyone!
What size are the belt slots? or are they sized to fit the pattern? They look pretty long, most holsters are sized to the belt they will be worn on to avoid movement during the draw. Molding looks pretty good, you might try rubbing the wrinkles out of the bottom of the triggerguard during the molding process, but I've never worked with horse so I don't know if that will have the same effect it would with cowhide. Overall, for #2 I like it!
S1's in the rear(on the back)...as always Not a great scan, but this is my mark.
I keep debating on where to place it, and I have decided for the most part I'm going to put it where it isn't visible while worn, if the owner is happy about it, they'll tell people who made it I hope. Speaking of that, my mark was made by Brenda at www.lasergiftcreations.com. Good customer service and it came out just like I designed it. This is the art she sent me:
As someone who is in the same boat you are, I bit the bullet and spent the money for a new Cobra Class 4 from Steve at Leather Machine Company. Steve was exceptional to work with and is easy to get a hold of if you have any questions. The only issue at all I have had with my machine was assembling it, the factory had forgotten to drill one hole in the base, steve had it figured out in 30 seconds when I got him on the phone, I pulled out the cordless drill and was sewing away within a 30 more minutes. It is capable of sewing very slowly when you master the foot pedal, so after just a couple hours practicing I was feeling very comfortable and starting to speed up. Can't say it enough, Steve was great to work with. I ordered my machine when I was in Iraq which made for some difficult communications, and Steve was more than happy to work with me and was VERY military friendly.
Latest holster out of my shop. This was originally a natural tan holster, but my 3 little girls were watching and wanted to see what my "Science experiment" did to leather, so I showed them on a scrap what happens when you dip it into vinegaroon...and what daddy starts to say when he gets a drop of it on a tan holster. Several bitten off cusswords later, the whole thing went in the tank, and I now have a black holster for my Model 19. Any feedback or suggestions for improvement (other than "Don't get 'roon on a tan holster" ) would be appreciated!
I ordered 15 models from Duncans in February for $45 per mold plus shipping. The inventory sheet they sent me then shows both the Beretta and the Taurus in Stock. For a copy of the inventory sheet you can email them at glenn.duncan@chartermi.net, it will have the current stock and prices on it. Luke handled my order, first class service considering I was calling from Iraq to order and my fiance was paying for it from the states, necessitating a bunch of calls between the 3 of us. Shipping was about $28 for all 15 of them, fairly hefty box
Buckaroo Bedroll
in Saddle and Tack Accessory Items
Posted · Edited by dmr400 · Report reply
One more picture, so it's a little clearer how it is put together. You can kinda see the seam of the pocket in this one.
