RML Leather
Everything posted by RML Leather
  1. I am assuming you are working on a soft rap around belt worn over clothing and not used to hold up ones pants. It this is the case and all your really trying to accomplish is keeping it from falling off the person, try sewing it on leather the that is the same size of your Velcro to be used, or if need be a in the center of a slightly larger piece of leather. Then glue this to your belt. (also helps to sew the Velcro to the top side of the leather (smooth side) so the rough bottom side works more into the leather and adds additional holding power. Hope this was of some help.
  2. Hello fellow craftsmen, Here is what I have been using to make patterns for years. The product is wallpaper liner that you can pick buy from most wallpaper outlets. Sold in single and double rolls, and is not that expensive for the amount you get. Wallpaper liner primary use is for just that, lining walls that have imperfections before applying the actual wallpaper. To get started unroll what you will need and then press with a dry iron (no steam needed) Then you can draw and make notes on the liner. You can cut, punch etc. fairly precise details, and it keeps its shape. This material is thin yet very durable, and can be used over and over again. When storing your patterns if they are folded, or what ever just iron them again when you want to use them. I am sure no one will be disappointed it they give this a try.
