jakeamon1
Everything posted by jakeamon1
  1. For those of you that make your own conchos out of coins, how do you "weld" the chicago screw to the back?
  2. I've made some conchos by using JB Weld, a pendant, and a rapid rivet. I taken metal pendants that are painted and roughed up the backside with a dremel tool so the weld would adhere well. Same with the rivet. Need to use JB with a painted pendant because the heat from soldering will melt the paint. You may be able to find a superman pendant that would work. Good luck.
  3. What is the best leather adhesive to form a permanent bond between 2 pieces. I would like to laminate a thinner piece of leather to a thicker. This would be for dog collars, so it would need to be flexible.
