jhardisty
Everything posted by jhardisty
  1. I just recently started leather work, hoiw does oine do the x stitch? Like the black vest on your site, is that also all x stitch?
  2. What kind of lacing/stitch do you use?
  3. Hi Most of the stitching tuts I seen on the web and in books show two pieces of leather against each other in a stitching horse. How would I sew or lace two pieces that are next to each other ie. edges together lying flat on a table? The leather is only 2-3mm thick and not very firm. Thanks
  4. Came across a book in a bookstore yesterday and saw something interesting. Unfortunately, the book covers quite a bit of what I need to learn (tools, lacing, stitching) but then also covers a lot of things I don't want to learn (handbag making, etc). So I guess I'm gonna have to spend a few days visiting the store and reading the sections I'm interested in :-) Anyhow, this is my first attempt at shaping the bottom piece of the covering. Basically, I outlined the drum on a piece of chip board, cut out the circle with a jigsaw, added to a second piece of board raised the approximate height for the overlap required, nailed part of the leather to the bottom board, then pushed the left over cutout down over the leather. Unfortunately, in my haste I did not take into account the thickness of the leather and the thickness of the blade difference, ie. leather thicker than blade, so it was an extremely tight fit trying to get the cutout over the circle now covered with leather. In the process, the one side cracked as it's only chipboard and not very strong allowing a slight fold in the leather at that point and scratching about a 2cm section of the bend. But it looks like it accomplishing what I wanted it to do, so far anyways. I'll only find out tomorrow once the leather has dried and I remove the cut out. But it looks good enough for now, especially for a first try...not folds visible. For future referrence I'll need to do the following. 1. Make the cutout a little bigger or if possible buy a thicker blade that will accomodate the thickness of the leather. 2. Use a stronger wood like pine or something. 3. Nail the leather done in such a fashion that it creates a "tent" over the shape, then apply the cutout and clamps so that it (the cutout) pulls/stretches the leather into the necessary shape.
  5. Those are my other 2 options, ie. a flat piece and then lace or stitch the ends. I just thought the shaping method would give a better finish.
  6. Hi In all the examples I've seen for tooling/carving leather, a light tan colored leather is used and then dyed black or whatever color(s). Can black leather be used seen that that's what I have or is it best to use the tan colored then dye it black? thanks
  7. Hi I've just started leatherwork, ie. read a bit, 1st project, etc. I would like to make a covering for a plastic paint bucket. The problem I'm having is making the base and top. I've done a test on a small cup by cutting out a circle larger than the base, punching some holes for string to pull it and tie on the top to maintain the stretch, casing it and then stretched and tied. The problem as expected is the excess leather creates folds in certain areas, how do I get rid of them so that I end up with a smooth fold/lip that can be sewn? The leather is reasonably thick as well, like 2mm but this would happen even with the thinnest of materials. thanks PS. Apololgies for the multiple posts, but the New Topic page just wouldn't do anything after submitting. It obviously did something in the background
