Tanthathide9
Posts posted by Tanthathide9
  1. Can u explain how u made your transitions. Did u taper your lace or did u braid it more like a Mexican whip. The whip I been trying to copy was done from the tip to the handle and he split his lace as he went up his desired length. How did u construct yours? What type of core did u use? Beautiful work
  2. Mother in law gave me this saddle just was curious to the history and what it might be worth. If it's of value I may have someone with more experience restore it before it tore into it. Gave it to me as a practice saddle. I searched the maker and said it's like a late 1800s to 1930s saddle maker. Leather for most part still seems good. Latigo and saddle strings need replaced but i haven't really dove into it yet. Pictures to come.
  3. I have kept the rendered fat in a mason jar in my garage I live in texas and the fat has not gone rancid to answer ur question. I chose a mason jar to deter critters. They sure like it. This same jar has been in same jar since I started the post and smells like it was just rendered....
  4. Yessir thank you. I lashed the rope to the handle and braided the rawhide core on top of it....i can agree where it kinks now that you mention the rigidness of the rawhide as opposed to the rope. Its smoother and might've caused the braid to ride up...atleast thats how i'm thinking of it lol. I used the rawhide string for a core on a quirt i didn't really want much weight to it since it was for my daughter and was really surprised with the stiffness just the lashed strings would bring me. You definitely shed some light on a few things for me. Thank you all for your help
  5. Yessir I'm familiar with rawhide I kept string moist and tempered good throughout process not too wet and definitely not too dry. Reason I ask about cores is cause I used half a cotton rope on 3ft of it and the rest braided rawhide and it's where the rope is is where it's kinky. So I was asking in hopes of THAT being my issue so I can find a better solution. I've heard of speedometer cable being used up to extension cords. Whatever was around for using. As from what I read u want the weight in the body of the whip not the handle as in a quirt. I must add that when I did try breaking it in before I passed it on it did get better but there was still a small curl to the top where it acted like it wanted to coil up if that makes sense. Please let me know if I'm giving yall the right info to help
    Tip not top. It curled at the tip of the whip
  6. Curious if anybody has tried to use anything outside of ordinary for a bullwhip core for those that have used or know of people who do use them. Also i made my first whip a while back and noticed it was kinda kinky. Questions: Do you let it try coiled up, straight possibly with a little weight on one end? Does it need to be "broke in" for instance like the reata is done in the B.G. Book where mary fields is pulling it through the fence post? Should that be done also cause when i tried cracking it where i was "kinking up" it would just get caught up in itself. after use it was starting to get more life to it but i was curious after the fact if i should've broke it in before. thanks to all who can help.
  7. I actually started from the end and worked back towards the handle. Started with 4 strands and the rest of my strands I used in the core for about 2.5 ft then I had some sash cord 3/8 in diameter for another 2.5. The sash was attached to the handle which was cover 2 ft from the handle in an 8braid just like in bruce grants book. Once I got to the base of the handle I had to improvise with a back braid cause along the way from my 8 to 10 transition I busted a strand so it went from 8 to 12 and yeah...I hope this made sense let me know if I can clarify. It was my first attempt
  8. Was fortunate enough to be given a hide. Bad thing is I went to pick it up and apparently they have a "hide room" which in my mind was a big walk in freezer instead it was more like a 3 sided cinder block shed with a 2 ft retaining wall and 1000lbs of salt for the hides they sell to someone. Obviously not the first choice for rawhidin it. But I told the man id take it so I couldn't fall back on my word. I dont k ow how long it had been salted but it seem like it was pretty thirsty but there was still play in it once I removed fat and meat. I know how its bad for the hide but long story short can it be salvaged. If u can give me a time frame like 2 days in salt would hurt it then im good. Im in unchartered waters now just need some help. Its such a beautiful hereford hide id really hate it to go to waste itll find a use but for braiding idk. Thanks yall
  9. Technicaly my 2nd complete project. I worked backwards from the cracker end to the handle. The ranch hand who made whips for my grandpa did it that way so I figured why not. Only difference is he started out with 4 strands then split them from to 8 etc. He finished at the handle with a back braid. I however started with 4 strands braided around the other 8 strands I would use and add 2 strands every1.5 foot or so. I finished with a back braid at the top as well. It was definitely a learning curve nxt attempt I would start from handle down and just drop the strands into the core instead of adding from the core. I had a strand break on me around the 6 strand braid somewhere and I got screwed up somewhere on the back braid. However its a functional piece it didnt fall apart and im happy with it. Learn with time so itll only get better. Thanks for looking and all opinions are welcome.
    post-23761-0-28096800-1429625759_thumb.j
    post-23761-0-55923600-1429625838_thumb.j
  10. Can anybody post the link to that video u speak of on tim george. I tried searching them and cant find them anymore. They were posted on here originally and as I watched them I found atleast 5 more on youtube but I can find them now. In those I found a clip that showed him cuting from the round. Just be nice to watch again if anyone had em thanks
  11. Thank you everyone who took the time time comment and lend their advice, it has not fallen on deaf ears i can promise you that...back in the "lab" gulf coast texas has some gorgeous weather right now so i will take to it while it's here
  12. now that it's had time to dry out completely, it's dried with a curve in it. bowed up. Could that be a sign that i didn't pull tight enough, if i didn't have enough moisture one can believe that u aren't able to get the best pull and make that lace lay like u want so...the curve would be the end result. am i correct? It's not stiff enough either it seems. could it all be because of a loose braid from lack of moisture in my string?
  13. Yessir u are correct diving in head first...and after it was all said and done there was A LOT that made sense. What is it that ur seeing that tells u I didnt have enough moisture?
  14. i know it's took long for one and i hated having to use so many strands....it's not a wall hanger for sure....i wanted to do the 6 strand back braid.....but like i said it is what it is gotta start somewhere....
  15. Works slow so I started putting this together with what I could fit in the lunch kit....It wasnt a well planned project as I started out with a 16 strand plant it quickly went south when I busted a string it then turned to a 14 and eventually down to a 4 is what I ended up with...ill prepared but it is what it is. Its been 3 years since I started learning ans I felt I learned more by doing this than reading and watching videos. A lat of aha moments and it clicked but guess gotta start somewhere....PLEASE give me all the feedback u can good or bad....post-23761-0-78063200-1412250583_thumb.ppost-23761-0-96578700-1412250768_thumb.j
  16. i tried to make a cutter and idk know if it's the rawhide or my cutter but it keeps wanting to twist on me....i tried pulling my string different ways to keep the hide in the slot designated for it but it still wants to twist out.....any clues as to why?
