Content Count
135 -
Posts posted by shooter55
SPF…….
Brand New Cowboy 3200 for sale. This is an extra machine that I purchased for a back-up to my CB4500, but can't say I think I'll ever need it. Will not ship, so you have to be in general area, or willing to take a road trip. My location is 30 mlles due west of Cleveland, OH.
$1195.00 FIRM. If you want to save a little on a brand new machine, this is your opportunity.
E-mail for questions. (tim@defensivelineleathers.com)
Before you commit to buying a Tippmann, check with Bob at Toledo Industrial Sewing machine. (Cowboy Bob here on the forum) He has a new model CB3200 for $1595 and it does almost as much as the CB 4500. I have them both and they work great. Just remember that with a Boss, every stitch means a downward motion using your hand and arm. Lot of up and down for a belt……..
No, I am not affiliated with Bob, but did stay at a Motel 6 the other night…..or was that a Holiday Inn????
"What do you guys think about stitching around the belt slots?"
MDH,
Have done them in the past by hand and machine. Not as a general rule though. As Dwight says, "adds to the look" , but if glued and burnished correctly, should not separate.
Very nice job. To chime in with Eaglestroker, it really does help when you pre-contour for the fit. My method is after it is molded and ready to dry, with the blue gun still in the holster, I take a piece of wood 1 ½" wide, ¼" thick and about 12" long and run to through both loops. I then press the wings flat against the wood where it is inserted. It will dry with a natural curve that fits the side a little better for break-in. I have a personal preference to double stitch around the gun, but single is OK too. If this is your first holster, you're on the way to being a pretty good maker. Looks like you pay attention to detail.
Keep it up.
WLG, sorry I missed your request.
Red....Do you dial that RPM down some way on your B&D? 3600 seems pretty fast to burnish an edge. Ever burn any edges? Just curious.
QuickBooks here. Like the reporting system. Never a problem.
I'm not an expert on tooling (as many here are), but I believe the leather quality may have something to do with the issue. It also looks like the knife is "dragging" and pulling the leather instead of cutting clean, which can be caused by trying to cut too deep. If your knife is truly sharp, it really takes minimal effort to cut a good line. You shouldn't have to exert a lot of pressure. The knife need to be perpendicular to the leather when doing this also. That will "bend" one side of the cut if you don't. The casing could be too wet, which can also make for a sloppy cut.
I'm sure someone here will identify what you are doing that is causing your problem.
Don't be discouraged as we all had to start the same way you are. The biggest difference, is you have the benefit of truly talented artisans helping you here. (myself not included).
Have fun....
Shooter55, I am afraid that is all done with a Cobra 4.
Still some time at the machine. Looks great.
I see a few hours of hand-stitching there. Very nice job.
Made one for a customer a while ago. Makes the holster wider, but apparently fits him OK.
Looks very nice.
I lay mine in the driveway and run over them with my truck. Also embosses with tread marks at the same time.......NO, not really. I also use a laminate roller. Don't use a sledge when a tack hammer will do. If glued properly, that and the stitching will create very strong bond.
Tim
sewed this skirt without a single hiccup I'm so happy!
Very nice work Seth. Are you stamping or carving? Either way, looks pretty good. Do you do a lot of saddlery in LA? (not to be confused with Lower Alabama or Los Angeles) Have some friends in Shreveport and the only horses they are familiar with are 390 if them under the hood.
Nice work.
Tim
That's awesome, awesome information.
Thank you for taking the time to write that! I'll start looking for dealers close(ish) to me.
Good news for me. I think the Toledo Industries folks are just a hop and a skip away from me in Long Beach!
Seth, Unless you have really long legs for a hop and skip , I think Toledo is farther than you may think. They're in OH.
It did turn out nice, though......
Very Nice. What kind of time do you have in this?
Very Nice.
Nice start. If you are like a great deal of us here, you will learn from your mistakes and each new project will show improvement in ability and technique. Don't be discouraged if you screw up a few (I have more than I want to admit). Read many areas on this forum and you'll learn an immense amount from experienced leather craftsmen. Good luck with your new endeavor and keep us posted on your progress.
As Dwight said above....you started out good. Keep going.
Tim
Very nice Seth. A lot easier than hand-stitching, huh? Faster too.
The contrast really catches the eye, great work. Are those all hand stitches? There are very uniform and well done.
Thanks for the compliments. In younger days would have done this by hand, but no, they are machine stitched. As you get older, your mind thinks you can, but your body comes to reality and says" what... are you stupid?"
Thanks again.
Seth,
This is not a note on how to fix the issue, but rather a 3rd party, no dog in this fight, observation. I can understand your frustration and initial knee-jerk reaction that the machine is bad. That may be the case, when this is figured out in the long term, but have to state that it appears that Bob, Bob Jr. and Ryan are all trying to help you in correcting this issue, regardless of the cause. Their reputation and history of excellent customer service and care are very evident in their communication, even though there has been, dare I say less than, fair videos put on youtube declaring that the issue is the machine. This is not a condemnation of what has transpired, but viewing this with some clarity from an outside observer.
I have a considerable amount of Cowboy product in my shop and, yes, have encountered some occurrences that have also frustrated me, but have always had the support and guidance in getting those issues resolved.
I sincerely hope that you find resolution to the issue and am relatively positive the responses you are getting from the 3 people mentioned above, will provide that.
Good luck and hope to hear how everything turns out.
Shooter
Shooter 55, If your holster drys a little tight take your gun or mold put it in a Ziplock Freezer bag then put the gun or mold and bag into the holster forcing in to the position you want it. Let it sit over night (no wetting of the holster is necassary for this). In the morning remove the gun or mold and reinsert into the holster without the bag, you should have a nice comfortable fit.
Thanks camano,
I posted in an earlier post that I do that and it has helped a lot. Doubling that is sometimes needed for really tight fits. Thought maybe there was something different in the molding process that could be different other than what I have been doing. Thanks for the input.
Cowboy Cb3200 For Sale.
in Old/Sold
Posted · Report reply
No. SPF means "Sold Pending Funds". Funds provided. It's gone. Sorry for not updating.
