johnnywalks
Everything posted by johnnywalks
Help! Which machine for this stitch please?
johnnywalks replied to johnnywalks's topic in How Do I Do That?
Is this any different from other cylinder arm machine? I do own a Pfaff and the arm blocks you from doing this type of stitch method. Thanks RockAussie! Extra tall post might be the best solution. -
Thank you! Yes I suppose what you mentioned is like those rotating cylinder arm machines I have seen. https://youtu.be/7ebT9aL6MDk Hopefully someone can offer an alternative way to get this stitch (besides hand sewing). -
Dear fellow leatherworkers, Need your expertise and advice. Which machine can I use to achieve this overlap panel stitch on both sides to close this tote bag construction? Is this only achievable with a rotating post bed sewing machine? I'm excluding hand sewing for this project. Thank you and appreciate any input!
Aww Thanks for the diagram!!!!!!! I manage to release the shaft and it moves...but how do i move bushing 3? I did loosen the screw set that holds it but i don't seem to able to move it towards sideways.
Hi!!!! Need help with my Pfaff 335 please. I'm trying to set my timing with a 134-35 DH needle size NM90 size 14. The tip of my hook is touching my needle and pushing it outwards, this needle is quite small actually. How do i move the hook (or needle) to give it a 0.05mm distance between both hook and needle?
Wow, impressive! Thanks for sharing your knowledge so far. Unfortunately my motor is a c face and it didn't come with any foot flange for mounting. Now i have to figure that out, either with some steel bracket or get someone to fabricate a steel frame to fit the motor vertical. 20mm inside diameter wheel is another issue, i can get someone to lathe the correct threaded bolt arbor for me, wonder what the costs are for such work in UK. My other consideration is using tapered end arbor, will they work? http://www.metalpolishingsupplies.co.uk/bench-grinder-spindle-adapter-5-8-16mm-right-hand-side/
- 42 replies
- edge paint
- polishing
(and 1 more)
Hope to learn more from you, thank you for sharing your knowledge Lobo! Sadly the fashion world at the moment is about rather keen on chrome tan leather with edge paint matte and smooth finish. In fact, the smoother the leather, the smoother the edge "the better". lol. However i think the Veg tan wax technique is making it's comeback slowly. Do you think the grub screws will work fin on the keyway slot of my motor shaft?
- 42 replies
- edge paint
- polishing
(and 1 more)
Have you try cloth only wheel? I was told by the guys from Mando FR even cloth with one leather is too harsh for final finish. I have a dremel with muslin cloth only and they do work but the rpm is too quick and i prefer to be "hands free" holding the leather. Besides, the dremel cloth wheel is too small to do quick runs for me. i just need this setup for small production runs and longer edges and of course build a better knowledge towards leather goods production. Italian mades like Omac, Ginev and German Sieck are all making this edge polishing machines for production and i am sure they exist for a good reason. Right about now i do need an opinion on the grub screws on the adapters before i can try it out! lol. And after solving the adapter issue I'll have to think about how to mount my C face motor vertical and boxed up just enough to be on a table as space is limited for me... sighs. Not giving up tho!
- 42 replies
- edge paint
- polishing
(and 1 more)
Just found this and looks like this guy is locking the grub screw with no issues. https://atelierdubricoleur.wordpress.com/2014/01/29/mounting-a-steel-wire-wheel-monter-une-brosse-dacier-rotative/
- 42 replies
- edge paint
- polishing
(and 1 more)
Thank you for your input, nice setup and lots of space! The intention of my motor is mainly to smooth out the edge paint's final coat rather than sand the leather edge itself. The horsepower is bit low on mine, but i think that does the job based on what i researched. I don't think i will look for another motor, these stuff are not cheap in the United Kingdom and am happy i got a decent deal off this variable speed setup. I was hoping someone can point the right direction to solve my keyway shaft issue of fitting an arbor that allows polishing wheels to be fitted.
- 42 replies
- edge paint
- polishing
(and 1 more)
Thanks RockyAussie, i was thinking of that too, but will the grub srews lock onto the key slot? i am thinking i can just pull the whole adapter out sideways? Hope any experts, engineers or anyone who had done this before can give their feedback. My shaft diameter is about 14mm estimate, which i believe a 5/8 adapter is closest? https://www.amazon.com/Grizzly-G5551-Arbors-8-Inch-2-Inch/dp/B0000DD4B1/ref=pd_sim_469_4?ie=UTF8&dpID=41CV-8WxEhL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=SQE5VVEPR61RKK14JGK1 Specs of my motor attached, i got this off eBay and it is variable speed and spins two directions. Also, i was trying to get the cloth wheel and i was told by my supplier in France their cloth wheel has an inside diameter of 20mm....seems rather hard to find an adapter of that size...
- 42 replies
- edge paint
- polishing
(and 1 more)
Hey guys, i had abit more time to my project and decided to go cheap/adventurous and try to build my own buffing machine. I got this variable speed motor off eBay, all fixed up with inverter, dial speed and ready to use. I thought i will just need to build a box to hold everything in place. Problem! - the motor shaft uses a keyway, which to my novice knowledge are generally use for pulleys. How do i convert a keyway shaft to hold typical adaptors with grub screws to hold buffing wheels?
- 42 replies
- edge paint
- polishing
(and 1 more)
Thanks JMWent. I was just very afraid the rpm of 3400 will melt the edge paint too easily. I may go with 1400 rpm to slow it down. But i am glad to hear that single speed does the trick and made the difference in your work. I guess i have to stick to my guts to go with DIY at 1400rpm and upgrade to a tried and tested manufacturing brand in the near future if need to. My only worry is that at 1400 rpm i may not be able to burnish with wood for veg tan leather. I guess i'll take it one step at a time.
- 42 replies
- edge paint
- polishing
(and 1 more)
Thanks mate, this gives me more confidence to build my own and find my feel of the DIY. Am based in United Kingdom actually, use to have Johnnywalker as a client/sponsor years ago hence the name. lolol. I read somewhere that to buff acrylic (which we assume has the closest melt properties to edge paint). Measure the 'Surface Feet Per Minute' at around 1400 - 4000. - Take 1/4 of the wheel diameter, then times the rpm of the motor. Example: 1/4 of 8" wheel diameter = 2 x 1400rpm = 2800rpm. It should be within that range to avoid overworking/melting. Hope to share this knowledge to anyone who is into the math solution. Looks like i will go with 1400 rpm and give it a shot.
- 42 replies
- edge paint
- polishing
(and 1 more)
Thanks eglideride. What's the rpm of your motor? Do you use them to polish edge painting final coat and if so the results? It seems to me wood burnisher is for finishing veg tan leather without any edge paint.
- 42 replies
- edge paint
- polishing
(and 1 more)
Dear fellow leatherworkers, I have been following this forum for awhile, thank you all for the tips and information. I am about to have my first small order of 50 pieces of cardholder. I have been using edge paint from fenice or Giardini for my edges of leathergoods. Here I always sand the leather edge down first to even out, then apply a thin layer of edge paint. Next I follow up with the electric creaser acquired from Mando, flattening the paint applied and then i sand it down again and repeat this process. I need the final coat to be smooth and well finished like any luxury leathergoods makes out in the market. I have look around in search of buying a brushing/polishing machine. Omac, Sieck and Randall Campbell stock the following machines: http://www.omacsrl.com/products/finishing/polishing-machines/brushing-machine-sp200/ http://www.sieck.de/en/machines/leather-goods-manufacturing/details/5499/ http://www.campbell-randall.com/machines/leather-goods-machines/burnishing-machines/model-vsb-burnishing-machine/ As these machines come with a hefty price tag, i am thinking of building my own to save cost, however with not much confidence as i am no electrician. I understand so far the motor has to be of the right rpm, horsepower, along with the required finishing wheel (felt, felt with 4 leather, etc). I am thinking either 900rpm or 1400rpm, 1 HP motor. My questions are: 1) http://www.ebay.co.uk/itm/110600633578?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Will this sort of motor work? how can i change the shaft/arbor to the right length and dimensions to fit AP size polishing wheels?? Should i use AP or LF wheels? What is the difference? 2) What about variable speed motor? It seems really hard to source one with an inverter and the price tag is pretty high. Can i use a servo motor for sewing machine and convert it to be an edge finishing machine? Am based in the UK and these sewing machine servo motor seem to be a better price. The only issue is how i can keep the servo motor spinning as we all know it has to be activated by a foot pedal. 3) Which sort of wheel do i use for the final finish of the edge paint? cloth and 4 sheet of leather wheel, dense cloth wheel, felt wheel? 4) Vertical or horizontal mounting? I am thinking vertical and i can build a similar box in wood as those commercial ones mentioned in the links, but my question is the weight load of the motor.. what sort of mounting i should use etc. Any experts, please help!! :((
- edge paint
- polishing
(and 1 more)
- 42 replies
- edge paint
- polishing
(and 1 more)
