Roger J
Everything posted by Roger J
Update...things that were tried 1)tried stuffing and wrapping sheath with tissue paper, tightly binding the whole in packing tape and put it in the oven with only the light on (maintains temperature of about 40*C) for two days, worked a little but not much 2)completely covered the sheath with a ton of baby powder and repeated the technique above. Worked much better this time as the talc was stuck onto the oil. After brushing, and wiping it down, it was evident that there was still quite a bit of oil to remove. 3)finally added a bit of dish-washing detergent to some lukewarm water in the sink and submerged the sheath and gently rubbed it with a rag. After two minutes the water became brownish-orange. I drained the sink and immediately repeated the operation two other times, for only a couple of minutes each. Then I patted it dry and hung it in the oven (just with the light on). It now feels a bit dry, but I'll wait a few weeks to see if any more oil rises to the surface. Anyways, so-far-so-good, I'm really happy with the results. PS...although the baby powder was washed off, one can still smell it and the leather feels silky smooth, but perhaps that will dissipate in the next few weeks
Last winter I made an axe sheath from veg tan leather and finished it with a mixture of wax and neatsfoot oil. All was fine, it had a nice dry waxy feel to it. *** Now comes the July heat, and the finish just feels greasy as heck and stains cloth an orangy-tan color. I've hung it out in the sun each day this week and wiped it down every evening. The cloth staining has decreased, but it is still there. *** Is there something else I could do to draw out the excess oil, or is it just the nature of the beast?
Cutting Leather At Angle To Create Retention Lip On Pouch?
Roger J replied to Roger J's topic in How Do I Do That?
Thanks guys. Bandsaw: not a bad idea as the blade goes only in one direction and they do make 1/8" blades with 32 TPI. All I have right now are 1/2" 3TPI rip blades...it would be a bit rough. Coping saw: I had thought the back and forth movement of the blade might give a ragged edge to the leather. I'll see if I can adapt some ultra fine scrollsaw blades to fit my coping saw. Might end up doing that, but it would feel kinda weird, like asking a chef for his secret recipe. -
Quite a mouthful I know, but this picture should help clear things up: Notice that the leather of lid and body is cut at an angle to "lock" in place when closed. I'm guessing that they probably use some type of press, and I don't think I could do this cleanly with just a knife. Is there a special technique or affordable tool that would help one accomplish this?
Thanks Kate (Wiz mentioned that )
Hi Matt, I'm really new to all of this and was not familiar with Will Ghormley nor Sedgewicks. After Googling, seems the first mentioned is is an old hand custom pro and the second is a well known English tannery. All I've read previously seems to point to the necessity of a baking soda bath to "neutralize" the acid, or else bad things will happen...I blindly assumed the leather would just fall apart, but have not seen any pictures of this anywhere. Anyone have pictures of "non-neutralized" vinegarooned leather gone bad OR surviving well without it for several years or decades?
Hi Ken, So I guess the issue, as Wiz first pointed out, is the size of the pictures people upload. I'll look into some firefox add-ons to see if one will solve the problem.
Hi Wiz, I'm using a PC laptop, 15.6" screen, and the resolution is set to maximum (1366 X 768). The ctrl functions work fine, but would be nice if it would just resize automatically. Just wondering it its just me that has this problem. Hi TR, Just tried your trick and it worked, now to figure out where it got saved to
When clicking on thumbnail pictures on this site, I often get these gigantic larger-than-screen pictures. I am using Firefox and this is the only site I frequent that has this issue. Is this a Firefox issue? Is there a way to automatically resize the gigantic pictures to fit the screen automatically?
Ya, I'm wondering if it is because it was made in such a small batch. Should know in a few weeks time Did the video come out OK on your end?
After reading all the posts about vinegaroon here, I just had to make some out of curiosity and for testing purposes. I made a cups' worth that came out orange, but works super well. 1cup 5% white vinegar, 1/2 pad (about six grams) of OOOO steel wool, and two weeks wait time. video of test on 1/8" (3 mm) veg tan: click to play photo of test piece after 12 hours dry time; cut in half to show center of leather is also black: Needless to say I'll be making more of this stuff
It really isn't in your neck of the woods, but I went here a few times: http://www.cuirsdesrochers.com They are more geared towards commercial clients (i.e. cobblers and such), but the two times I went there they were pretty nice folks.
Where are you located? There might be a bricks and morter store nearby.
It seems to be fine now (48 hours latter)
Is The Vinegaroon Gas Dangerous/smelly?
Roger J replied to Roger J's topic in Leatherwork Conversation
Thanks guys. To be safe, I'm going to make it in a 2liter pop bottle. Fill it halfway, collapse the bottle in on itself and put the cap on tight. Any gas produced will have a good amout of room to expand. As long as gas production happens slowly, it should be easy enough to monitor. Wish me luck -
It is winter and I heat my shop at a bare minimum when not using it. I'm thinking about brewing a batch of vinegaroon in the south facing window of our living room...the warmest part of the house. Does the gas emitted just smell like vinegar? Is the gas dangerous in any way?
Thanks guys. I must have rinsed too well, and the metal particles must be deeply imbedded in the leather because 24 hours later, a slight greyish spotting reappeared in the main area (it was still fine after 12 hours). I just reapplied the some OA and will leave it alone this time to see what happens.
