Ranwulf
Everything posted by Ranwulf
  1. From the album: Flask Cover
    Missing is the cap, which slides down over the sides of the case with a stitched "buttonhole" for the neck of the flask to pop through. The thing was snapped up before I could get a pic of it. The top edge of the cover was (later) whip stitched - the friction between that and the cap keeps the cap snug.
  2. From the album: Flask Cover
    Tiny stitches. This is waxed sinew, I think - been a while since I made this.
  3. Ranwulf
    No dye
    Since the person this was made for was likely to keep it in a pocket, I decided to forego dying - no sense in risking dye transfer!
  4. From the album: Flask Cover
    It's always fun stitching on a curve - the inner stitches get reeeeeally close together.
  5. Thanks. It's really hard to say how long it took b/c it was a side project at work - on again, off again - over a period of several weeks. Probably about 12-15 hours, at a guess. The oak core was the most time consuming part - done with chisels b/c I work at an early 17th c. site where post-1622 tools are verboten!
  6. From the album: Early 17th c. backsword scabbard
    This only needs a baldric, which is in progress.
  7. From the album: Early 17th c. backsword scabbard
    The wax protects the leather from the elements (it'll be outside a lot) and gives the oiled, unstained surface a nice glow.
  8. Ranwulf
    Say "ah."
    Looking down the throat.
  9. From the album: Early 17th c. backsword scabbard
    8-10 oz throat (I think). I applied neatsfoot oil with a wool dauber about 6 times, then applied beeswax. No dye used.
  10. Ranwulf
    Risers
    The risers aren't as defined as I would want, but I'll improve on that next time.
  11. From the album: Early 17th c. backsword scabbard
    ...and I'm glad there was: the shrinkage was probably less than 10%, which was still enough to make a tight fit around the wood core.
  12. Ranwulf
    Error!
    The stitching wanted to veer off, and twisting/adjusting wet leather on dry wood is difficult. I stopped and began again from the bottom, and met in the middle. This controlled the veer, but it's still crooked. Oh, well. Also - the seem is hardly a nice, flat one, but then this scabbard is for a munitions-grade sword, very much NOT a gentleman's piece - rough and ready.
  13. From the album: Early 17th c. backsword scabbard
    6 oz. cased leather; saddle stitching the seam. The risers are just strips of 6 oz. leather Barge-cemented into place.
  14. From the album: Early 17th c. backsword scabbard
    Ready to wrap in cased leather.
  15. Ranwulf
    Chape end
    Backswords generally aren't symmetrical, so the chape end tapers up.
  16. From the album: Early 17th c. backsword scabbard
    Sanding is the last step before stitching on the cased leather.
  17. From the album: Early 17th c. backsword scabbard
    Started by chiseling out sides of 2 oak splits - poplar would be more traditional, but oak is what I had.
