treborterb
Everything posted by treborterb
My First Leather Sewing Machine...lots Of Questions?
treborterb replied to treborterb's topic in Leather Sewing Machines
Thanks for the updated link J Hayes -
J Hayes...the link didn't work for me, thanks for trying though. Stanly, I just downloaded a free service manual and parts list for the 29K71 from the Singer link you provided, thanks for that. On another note...the timing of my bobbin and shuttle is off enough to prevent it from picking up the bobbin thread. The hook stops about 1/16 of an inch short. If I remember right, Wizcraft had posted that the tiny set screw that is located in the end of the bobbin shuttle/carrier assembly should be checked to make sure it isn't loose. I actually removed this set screw (it passes through the shuttle carrier and shuttle pinion gear) and it looks very worn...the tip is ground to a fine point and it is perhaps 1/8" in length. I attempted to order a replacement but it seems that singer had used two different sizes of that set screw in the 29-4 and the one I'm supposed to have is part no. 327 and is nowhere to be found. I have been told by Harry at Pilgrim Shoe that the one I need is the smaller of the two that were used on the 29-4. If anyone knows where to locate one of these set screws and can give me any info I would appreciate it. -
That is AWESOME...exactly what I was searching for. Thank You Orrin Would you have a link to the exploded view of the 29K70 diagram that you mentioned Stanly ? -
Thanks Bob...so the 135x16 Organ needles wont necessarily have the scarf you describe on them, or do all the current replacement needles for the 29-4 have the scarf incorporated in the needle design?
Wizcrafts...I have been told that the system 29x3 and the 29x4 leather point needles were no longer in production and that the existing needles of the 29x3 and 29x4 variety were slowly being replaced with size 135x16 and 135x17. I have seen advertised 29x3 needles being sold in 10 packs for as much as $13.00 / 10 pack and advertised as limited supply and "no longer available when gone", as well as 29x3 and 29x4 needles for sale on ebay for a fraction of the higher price. Can you shed some light on this topic. Is there any truth to the discontinued 29x3 and 29x4 variety/type of needles and is there really any difference between the higher priced 29x3 needles... other than their higher price?
I'm not able to check for Bell Crank wear because I'm waiting for a replacement stitch adjustment screw with the gib and small square mounting bracket...but as soon as I get it I'll be able to run the machine and then check the presser foot for wear in the Bell Crank Lever by placing the presser foot lifter bar in the up (raised) position and checking to see if there is any movement in the foot...is that right? As far as checking for wear in the shuttle drive gears, those are located in the arm carrying the bobbin shuttle assembly, right ? Is there a way to check this for wear or is it just a matter of removing the plate covering the rack and pinion gears and visually examining them? What exactly will I be looking for? Will the wear be obvious or is there a way to check how badly worn the part in question is? (and what part am I looking at/for?) I understand that its important to invert the machine and note the position of the gears because by removing the plate covering the pinion and gears, they will fall out and the timing will be affected if the gears aren't put back exactly the way they came out.Thanks.
Where can I find more info about the high tenacity polyester...I'll be googling it but sometimes someone will have sources or links that can be difficult to find solely by using google. Thanks.
Thanks Darren...already have that same parts list as well as a few others. Got my parts from Bob Kovar at Toledo Industrial. I think I have almost everything to give it a test run (and I say almost because he forgot to add a part to the order and is shipping it along now), so when that last part...the stitch regulator, gets here I can test it out. On another note...does anyone know the best way to clean the outside of these machines without damaging the decals?
Is it possible to reposition the balance wheel from the right side to the front of the machine on a Singer 29-4?
Thank You Gump...will do.
OK...don't feel so bad now...after talking to someone who sells/supplies the parts for these machines and admittedly worked on over a thousand Singer 29K machines...there doesn't seem to be any clear designation for the machine part groupings. If someone more knowledgable can tell me what they categorize the various assemblies (or part housings/groupings) it would be much appreciated. If I don't have the exact part number/name already... I can't just refer to a specific area where the part I'm trying to replace is housed. These machines are fairly simple in construction so eventually taking it apart and noting the name and part number will ultimately get me familiar with the parts but still leaves me stumbling to explain what area I am referring to without a part number/name. Would the part housing the needle/foot be called the needle housing, or the arm that contains the shuttle/bobbin be called the arm assembly??? I'm nitpicking really, but for the sake of expedience I would have thought these areas would be clearly defined.
Thanks again Darren...being completely new at this, I am not quite sure but will be finding that out and I'll give Bob a call back and run that by him.
Thanks Darren...I'm sure you're right but can't resist trying just to see if it'll work.
Thanks Constabulary...gotta look into that.
Excellent info as usual Wizcraft...just talked to Bob again at Toledo Industrial sewing and I have the equivalent of the size 18 needle (110 I believe) coming, as well as several larger sizes and the Tex 92 thread as well as the #69 on the way. I was trying to inquire of Bob on the availability of replacement "feed cam" parts and he wasn't sure what part I was referring to, so I told him I would try to get a part number for him, but, I thought I remembered someone commenting in another thread that certain parts aren't to be had any longer and if those are too badly worn, will basically relegate the machine to large "boat anchor"status. Hoping my machine doesn't fall into that category. In another thread, if I recall correctly, it was possible to test for excessive feed mechanism wear by attempting to move the lifted presser foot and if it had 1/16" or more of play...it indicated an overly worn feedcam part/parts. I'll have to try to locate that particular post to make sure I'm not taking things out of context. Got home and spent some more time cleaning and oiling on the 29-4 and things are coming along but have to wait for my parts order to arrive to do any real testing. A little embarrased to ask such simple questions, but when you speak of "ascend with the knot", do you mean after the needle passes through the material and picks up the thread from the bobbin, it forms a knot on its return, upwards through the material? Nice to know that a well timed machine in really good condition is capable of that but I'm afraid my machine isn't quite in that category (one can hope though)
Thank you Wizcraft...I will be going over the manuals and diagrams when I get the time to sit down and properly look em over. Have already started looking for my next machine as I slowly learn the advantages of one machine over another, I can't help but feel the desire to upgrade to one of the newer models (funny to be using the term newer when discussing these 100+ year old machines)...I have images of the 29K 70 and 71 and 73 as well as the model 29K 60 and 62...all of these machines I believe to be newer, improved models over the 29-4. On another note...could you tell me what would be the largest needle size and thread combination that the 29-4 could possibly handle considering its age?.
Thats good news...keep hearing that if the gears in the arm that holds the bobbin are'nt replaced correctly in reassembly, it could lead to all sorts of problems...so I have to hope that they are in correctly now and make sure that they go back in the same way I take them out. Good to know that I can refer to the diagrams for another model to at least attempt to disassemble and clean the top half...thanks.
Are any of the schematics for other Singer 29K machines close or even remotely similar to the 29-4? Can any portions of the other 29K machine schematics (such as the 29 71) be used to aid in assembly/disassembly of any portion of the 29-4?
Just a little background on how I ended up on this forum...I wanted a canvas/leather sewing machine and started looking a year or so ago and recently found the 29-4 for $125.00 but the Head revolving foot handle/bar revolving joint was frozen and wouldn't allow the foot to rotate in either direction as well as the Balance wheel would rotate about a half turn and then bind up...bought it anyway and after getting it home and with liberal use of penetrant, the foot began turning freely but the balance wheel wouldn't free up. Finally removed the part at the topmost point on the top of the assembly that holds the needle/walking foot assembly (where the thread passes through a hole in a piece that moves up and down)...I think its the vibrating presser lifting lever and spring (or is it the check lever, they look alike in the parts chart) repositioned the lever and replaced the check lever spring and viola...it began running smoothly. Now I can't wait for the new bobbin,shuttle and needles,thread etc. to get here to test its sewing capabilities. Fingers crossed, it'll work as it should. I realize that I still have a long way to go in getting it to run, considering I am not sure how to even install a needle,let alone time the needle to pick up the thread from the bobbin...it'll either be alot of fun working through all the rest or a complete disaster.
Thanks sgheeter, found lots of info and images Spoke to Bob this AM and have and order in...thanks again Wizcrafts. Thanks shoepatcher...able to order parts and starting to figure out placement and nomenclature but when it comes time to fully disassemble for cleaning and refurbish, I'll have to make do with the available material I was able to get with all of your help...thanks again for all the help.
Thank you sir...have to say that I enjoy reading your posts and originally formed my question as a result of a response you made in another thread. Picked up a 29-4 and have been trying to get as much info on it as I can to get it running well again. I have found a fair amount of articles about this machine but there doesn't appear to be any diagrams that allow one to identify the parts of this machine. My limited knowledge of sewing machines and nomenclature doesn't help either. Got to admit that I am a little surprised that there aren't any schematics to use for part location and identification for this machine. Thanks again.
Is the feed mechanism under the head (the feed cam) replaceable on a Singer 29-4 patching machine?
Thanks will do. It would be great to get ahold of a parts list/ breakdown type schematic to be able to identify the parts that others discuss here and on other sites.
