SovereignVS
Everything posted by SovereignVS
  1. Wow Leathernerd! Thanks for the response. Like you said, the best thing is to experiment, test and see how it goes. I'll let you know how it turns out.
  2. I plan on making wallets, tablet cases, purses
  3. I was about to buy the metal V- gouge from Springfield Leather. I'm wondering if this gouge has the same issues as the one from Tandy.
  4. I have a hopefully not dumb question. I was wondering when using oil tanned leather, will the oils rub off onto clothing and cause a noticeable stain? Will the dyes rub off? Will it with veg tanned? I just want to make sure I'm using the proper leather for things I want to make without it coming off onto cloth.
  5. Thanks Penguineer Wow cardboard and rouge...never would of thought of that. Anyways, Do you have a recommendation for a better knife?
  6. Sounds good. Yeah I've talked with Kevin before through Email. He was quite helpful. ANyways, I'm not sure what I don't need on my list. It all seems essential for what I'm doing. I might even need some more tools. I guess I could get away with not buying any finishes. Also I am going to be using a utility knife for cutting, unless there are other recommendations...
  7. would SLC be a good place to order from? I've heard both good and bad things about them.
  8. Thanks! I'll watch the video and see what I really need.
  9. Also getting a rotary cutter...either fiskar or olfa. And an HDPE cutting board.
  10. Hi I'm new to the forum and new to leatherworking, but its fascinating to me already. I've made a list of hand tools I'm about to buy and need some guidance to make sure they're good. Are these a good choice? What else might I need? My first project is going to be simple, a wallet. Then I'll make a tablet case. Here are the tools/dyes/etc. from Springfield. I'm thinking I might order some from Osborne. 21-251001 Cement,Contact,Barge 2oz 34-01 Gum Tragacanth,4oz 34-211002 Dye,Fieb,Oil,Dk Brown,4oz 34-261201 Finish,Carnauba Cream,4oz 34-222001 Finish,Tan-Kote 4oz 88-145 Awl,Haft,Stitching,#145 011-811600 Folder,Bone (Plastic) 011-809100 Overstitcher,Set,Sz 5,6,7 28-3003 Punch Set,Mini,Heavy Duty 011-808200 Gouge,Adjustable,V,Metal,SLC 011-807400 Groover,Stitching,Adjustable 88-54 Blade,Awl,Stitching,2" 011-807603 Edge Beveler,#3 130-119500 Needle,EZ Thread,10pk 130-001 Needle,Harness,"00"Med,2pk 97-5000 Thread,Waxed,AsstColors,5pk So anything you would recommend? to change? to add? Thanks!
