Everything posted by Dave84
Bringing this thread back to life. Which of these models could someone recommend for making leather jackets? I use an .8mm and a different 1mm cowhide mostly and will start to use horsehides soon. I also will run some horween veg 5oz or less through it some times. Jackets will be the primary and my vintage Adler 167-373 has trouble getting over thicker seams.
Hi all, I am looking to see if it's smart to upgrade from my Adler 167-373 to either a Juki 1541s or 1508n. My main use for the Adler is leather jackets and some Horween bag work using 5oz or less leather. I do run into some difficulties with the Adler for leather jackets that I had posted about years ago and the solutions didnt really make a difference, especially on the transition of slimmer seams to extra bulky seams. My Juki 8700 lockstitch can handle so much that I am looking to see experiences with either Juki above would be a huge improvement over the vintage Adler. Thank you.
Thank you Wiz, I will be looking into the first two. The Juki has been recommended to me several times as well. On another note, would you happen to know or point me to a source to replace the needle bar on my Adler 167-373? I cannot find anything nor is the manual clear on what the order of operations are.
Thanks KGG. To see if I understand, the Adler 167 I have is an upholstery grade which I believe does have 1/2" of lift, but isn't strong enough to handle denser seams. The next step up into walking foot industrial machines is a significant jump to $3000-$10000. Does Juki make a medium duty leather sewing machine that can handle heavier garments? Aven, Thanks for the reply. I hand skive veg tan for bags and belts but will definitely research the videos. I'm currently using .08 chrome tan for the jackets and hand skiving I've not had success with.
Hi all, I'm updating this thread and would like your help. My Adler has been working just fine on denim, other heavy fabrics and light leather and will keep it for those projects. Now, after doing several jackets, some perfect, larger percentage still having an issue of wandering needle from deflection at thicker seams causing wavey lines at these joints, although tamed immensely over the years, I'm done with my system of avoiding as best as possible all above. One comment on another thread mentioned hitting the limit of this Adler 167-373. These seams can get to a 1/2" unskived on .08mm-1mm leather so what machine would be the next step up for jacket making, bags, wallets? I'd like to stay with a name brand for easy parts, service and Youtube tutorials. Thanks
Hi KGG, I'm updating this thread and would like your help. My Adler has been working just fine on denim, other heavy fabrics and light leather and will keep it for those projects. Now, after doing several jackets, some perfect, larger percentage still having this issue although tamed immensely over the years, I'm done with my system of avoiding as best as possible all above. One comment mentioned hitting the limit of this Adler 167-373, so what machine would be the next step up for jacket making, bags, wallets? I'd like to stay with a name brand for easy parts and service. Thanks!
Thanks Michiel. I did think MAYBE the bar is bent, but would you know how the frame could get messed up? I've had this Adler for several years and this issue just started happening. I have had a few times over the years where needles brake hitting the lower feed dog when I try to stitch too much leather freely, not glued or taped, have learned that lessen. But a couple weeks ago I had to rotate the bar to get the needle to line up with the hole, it got that bad. Where can you recommend to start replacing or tuning?
Anyone have any insight as to why I had to rotate the needle bar? I'm noticing thread snapping more often, no doubt due to the thread being dragged across sharper angles of metal.
Hi All, Having an odd issue I cant find much info about, besides the concentric location, of the needle bar on my Adler 167-373. I just had to rotate it 90 degrees so know the thread guide hole is facing away from me instead of to the left, the needle was hitting the side of the feed dog, snapping needles. It seemed to just happen out of nowhere, but now its a pain to thread. Thoughts? need a new needle bar? 2023-01-24_09-37-41 by Dave Hamilton, on Flickr Next, I'm sampling some wallets machine stitched but I always have this issue, so I thought I'd ask. The bobbin side of the stitch always comes out super flat and the holes look more shredded. Using a diamond tip needle with poly thread. How can I make the bobbin side look as clean as the top? I do wonder though am I looking for perfection? I see some machine stitched items out there where both sides look clean. I've double checked that the loop is centered and it is, the bottom image shows the blow out/tear out. Refer to above pic as that's the current setup, a zipper foot with the feet smoothed out on a grinder, bottom feed dog never gets changed. Inside of wallets, faces up while stitching: 2023-01-24_09-37-33 by Dave Hamilton, on Flickr Outer shell faces down, bobbin thread side: 2023-01-24_09-37-25 by Dave Hamilton, on Flickr One last thing, looking at a Consew 277-R3 that looks good for $1500. Should I just buy it as I plan on getting a cylinder arm in the future? I'm impulsive lol
Dude got back to me and said it is older and best offer would be accepted. That's always risky
No it is a skiver. That's the motor tag? Gotcha, will update in when I speak to the guy tomorrow hopefully.
Hey Everyone, I found a guy selling a Lewsiton Shoe Machinery CO Leather skiving machine from 1977. Info on tag reads: Ch [6] HP [1/4] Date [1977] Ser. NO [660102] I can't find much info, but before I purchase at $855, can anyone give me insight into the company and machine? Is it worth it? I'm skiving down 5/6 Oz Horween for handstitched bags. -Dave
Yes, it is partial resting, continues to pull the lesser section causing some weirdness in the stitch line, but the thick part stays in place at the presser feet. Any solution on fixing that? Thanks, I'll start looking at it. Razor blades I have plenty of! Using garment leather seems to be extra tricky. Might just shift some of these extra folded parts around to balance out too much thicknesses.
I'll definitely try moving up on needle size. Your second paragraph is spot on! There isn't much room for the feet to move at all. I have a similar situation on denim, when there's a thicker part of folded over material then jumping to a thin, 2 layer section, make sense? Never could really find an answer as to why that is, plenty of foot travel. I've been looking into skiving a little, but dont know much about it. The amount I would need it doesnt justify a hefty pricetag though is my first thought. Any good hand tools out there you could recommend chrisash?
Thanks kgg for your input. I know the Adler can handle leather, been using it for a while, but these areas of more density than I usually stitch together is frustrating. I'll call Bob at Toledo and try some thicker needles but am concerned about the punctured hole size, even with a tex 105 thread. I may ultimately rethink my lining structure instead for now.
Just uploaded again. Material thickness I'd say is 3/8" to 1/2", folded over buffalo hide of 1mm if I remember correctly. My machine is an Adler 167 walking foot, tex 80, 135x16tri 125/20 needle. It's the seam just below the belt loop if the image is not straight but 90 degrees. It didn't rotate on my phone lol.
Hi Guys, I've been battling this demon for a while now. I make motorcycle jackets and rock n roll vests, areas of multiple layers of leather when folded over for the finish topstitch, cause the needle to ricochet while penetrating to the left, causing the needle to hit the bottom plate and break. The needle will go through the first few layers then ricochet, i think from too dense of material. But how do top companies like Schott and Vanson have such a nicely finished product? Using 125/20 Organ leather needles with Tex 80 Polycore thread. I hammer these dense areas with a ball pen to flatten as best as possible. I can mostly get through these thick areas by hand cranking only, testing to see if the needle bends to the left, lifting up the top dog and wiggling everything over so the needle goes through the bottom plate hole. It's such a pain and doesn't always give a straight stitch, sometimes from the ricochet it has a wonky line of stitch. In the attached pic, heres an example of these dense areas. to the right of the belt loop, you can see the wonkiness of the stitch! Thanks for anyones imput.
Been a long time since I've been on here. I'm looking for info on Adler 167 feet. I'm looking at two options for zipper feet, a left and a right, on Amazon. Right Zipper Foot Set For Durkopp Adler 167, 267 Industrial Sewing Machine -Genuine Parts (Foot Set) https://www.amazon.com/dp/B01EXG4QFG/ref=cm_sw_r_cp_apa_i_GRC2Db26NX446 Are there two parts to the assembly? It may sound dumb but there are two listings I've come across for a right and left zipper foot :). Secondly, is there a good source of info breaking down other optional feet for my Adler 167? I've moved my business into motorcycle jackets and want to really polish up gight stitching. The standard foot has worked out fine, but need to get that little bit closer.
I'm leaning towards a walking foot zig zag. Should I need it for multiple layers of leather, full construction or patchwork, better to have what I need. I've been looking at the Reliable 2600ZW? I've been told Consew is not worth it at the steeper price, especially if this is not my main machine. My Adler 167 is my workhorse.
I've been searching local and have a salesman who sells consew 199 for $1700 brand new, it is not a top feed, claims for what I need, attaching leather and denim patches on denim, this will be just fine, still slightly more power than I need. In anyone's experience, what do ya think? I can see how it should be more than adequate, keep in mind I work with a 10oz stretch denim, 2.5oz or less leather. Pants and jackets Slash from Guns N Roses would wear, not farmers denim
Ralf, thank you for the knowledge dude. I'm keeping my eyes peeled for a Pfaff 138 then, which ever I can get my hands on. I'm also going to talk to my local used guy about Adler 98 machines that he could have. These are the two I've narrowed my search for. Anyone have experience with the Adler 98?
Uwe, thank you very much, your video helps a ton. What do you know of the differences between the Pfaff 138 and 130? I have a 130 closer in distance to me, but do want the industrial strength zig zag. Based on your demo, I would be quite happy with the 138 after testing several runs of only leather, with it not being a walking foot that's the last test.
Thanks Uwe, looking forward to hearing your results! I'd prefer a 138 after researching this morning.
But in all seriousness, very very serious, the singer 143 and Pfaff 138 machines, can they handle multiple layers of leather, have reverse, run 92 poly thread, have the ability to be connected to a servo motor, etc? I am seeing both on Facebook marketplace for prices I really like for a machine that will handle on zig zag on leather
Hardy-har-har and maybe someone will give each of us one for free.
