Everything posted by helena
Mystery nut comes out of machine while sewing??!! Singer 153
helena replied to helena's topic in Leather Sewing Machines
Thanks Jimi!! i will have a look found this listing on e bay for a similar one :) this collection of screws can also be used as a reference chart -
Ok I switched out a needle guard with a durcop spare that came with machine jeesh probably will be ok now, thanks Cowboy Bob!
However since the needle bar and the needle is a fixed point once adjusted properly the hook now has the rigth high.Are you supposed to be able to move the adjustable arm around just by touching it? See movie above for illustration.
Put a mini movie on gplus
The arm is like free flowing and does not seem to respond to adjustment.. it hits the hook when handwelling or sewing. I myself did not mar the arm looked like that on arrival.did however disassemble the hook manny times and possible was to stupid to realise overlooked something. Should it be lose,? I oiled up the machine it was not free-floating when I got it.My concern is that it hits the hook after a few turns.since it can move freely up and down . Fulcrum only restricts side movement. And adjusting it seems that the arm moves in random and gets waked by hook.
I got lost in tension and am running a #24 singer 135x16 TRI with 207 poly thread in Leather cow hide it worked beautifully.Then I got cheeky and set out to change the lift of my feet, well adjusted it back to factory only to adjust the tension wrong and my current problem is I was thinking that loosening bobbin mention would make top tention able to pull thread up but it's not working. How does one even feel tention the bobbin thread just seemed the same with the screw adjusted all the way in One day I will learn bear with Helena
I just got hung up on thinking it was binding but now formed a brand new theory my bobbin is so worn that it starts skippingunder load . This is why the machine was out of timing and slipping out of timing once I set it. Turns out to be a wild goose chase, I got it timed but can not figure out why it is not pulling the stitches upp from the feed dog.
Since I am guessing,it is the mechanical arm setting. I just can not get to work right.if I set it tight hook gets stuck.s setting to a wide gap it move to stick later, intermittent and overall crappy.
Thanks again I was going crazy not knowing what needles I had.
Thanks Uwe but page18 in manual tells me feed regulating spindle head to 0 then remove throat plate turning machine pulley until you see the lower mark is just visible at the end of the needle bar. If timing is right everything should be in proper position. This is how I had to adjust mine since it was set to low. I got the machine and it just had tree needles in the box with parts they are 38 mm so it is not then the cat 3370 135x16 I need #24 with a leather tip and my eBay order is 30days lost.but now I know perhaps I am sitting on the 24x1 needles that the Britt's want
Been to ismacs and online sources is there a singer book for shops or say factory service men manual that covers exact models like the 153 The manual I got is a bit skimpy -Helena
Granted it is not the right way and with my limited ability I was looking for a shortcut to get going with my machine.my singer 153k103 once I adjusted the needle bar to the right height as defined in the manual the needle I got runs to high for the hook.. I could have the wrong needle Or can it get so worn out (the hook casing itself that it runs low) there was durkopp marked hooks with the machine that slid down perfectly however they do not have the other part that the hook rest on with it and I dare not even try. Should I just lower the needle bar and forgetting it? Assuming it will not hit the foot? Does anyone know the length in mm for the #24 singer needle?135x16 TRI ? In the manual it also states that the mechanical opener will cause a bind if it opens to much however I find it to preform opposite, when adjust it in it binds and the hook will not move if I adjust it out it starts moving. One day I will learn bear with Pulling my hair's out Helena
not feeding material adjusted feed regulating spindle head
This is how it looks regardless of my adjusting Here is a movie of my trobles -
The shaft will get forced out if it is in the "master" setting where you can govern it to not sew a longer stitch than desireble.If i do the same with it set to 8 leaving it hella loose or pinning it down to the rod itself the material will not feed just feet hopping on the feeddog. like there is no adjusting it that is why I was thinking that perhaps it is binding the feed fork so there is no rocking movement just up and down bouncing. I was contemplating just trying to get one adjustment but even though I can get it to be stable at say 7 any adjustment shows no forwarding movement of material or feed dog not working away from the operator just feedog going up and down. -
Ayy More coffe Eric and Cowboybob Thanks I do have been adjusting it and it does not do anything I have the same manual in paper print,Did all adjustments there is but only punching one hole with the needle...grr ! imageproxy (1).php -
Thanks I do have been adjusting it and it does not do anything I have the same manual in paper print,Did all adjustments there is but only punching one hole with the needle...grrimageproxy (1).php -
Going insainer I have adjusted the feed regulating spindle head thinking it somehow got locked in a bad adjustment. When I got the singer 153k 103 as it is in sweden the stitch regulator "thumb screw" was out so the numbers where to th rigth of the cut out. the groves or spiral tread that guides the set screw down pushing and locking the metal rod inplace where damaged so it could not be guided in once I got past that I can feel turning the adjusting screw how it can now pusch it out. Regardless is it safe to assume that the longest stitch 6 to the inch in this case is the feed driving eccentric bouncing off the thickest part of the rod? and if so why can I not make it feed just for a stitch by hand turning the wheel. I just wanted to sew...so I whent ahead and adjusted the feedbar with my limited/non existing knowledge about sewing machines this is maddening.som previoues clown lost a screw however the never one seem to hold the tapered gib and does not bind the tapered gibb at all. so now I am just frustrated not understanding what and how to adjust this.. this has alternating pressers in addition to compund feed so it is indeed a walking foot.
