Thank you Uwe and Kgg for your response. I have video for you to look at, but I can't get them to upload here. Suggestions?
	To answer your questions, right out of the box, I had problems with the machine. I wonder if it sustained damage in shipping from Toronto to Idaho, although there was no visible damage. The first thing that broke was the little stud on the thread tensioner. Techsew sent me a new tension assembly, and then I was able to sew with it, but the machine didn't sound right, and really didn't run smoothly. It jammed frequently, and I had to reset the needle to hook timing frequently. Then, the bobbin opener broke off. While I was sewing, the machine suddenly jammed and made a noise that did not sound good. When I removed the bobbin slide cover, I saw the finger of the bobbin case opener broke off and was jammed in the space. Techsew sent me a new piece and made me videos with very clear, detailed instructions to remove the remaining part of the bobbin opener and install the new one. I am convinced this was a factory defect; the piece actually broke in half at the bottom of the finger. After replacing the piece, the machine ran better than it ever had; it was running quietly and very smoothly - except it would only stitch in place. So, this is what I did, in order:
		I checked the feed dog height; no adjustment needed, as it was sitting exactly 1 mm higher than the throat plate.
		I checked the longitudinal motion of the feed dog and it was moving correctly, front to back. The needle was perfectly centered as it entered the feed dog, and was in correct time with the feed dog movement. No adjustment needed, thankfully, because I don't know how to make these adjustments
		I checked the height of the needle bar and it was off, so I adjusted it to the exact height stated in the Techsew manual.
		I checked the timing of the needle and hook, which was perfect. I did have to adjust the clearance slightly between the needle guard and the needle.
		I watched Uwe's video on YouTube for the timing of the bobbin thread release. I took a video of my machine timing and attached it here; I made no adjustment, because it appears to be okay, but please let me know if it looks off to you.
		I checked the threading of the machine, the thread take-up spring, and the tension of the upper thread and bobbin thread. No adjustments made.
	This morning, I adjusted the stitch length adjuster. Now, it will stitch, but the stitches are not the correct length, and it is not in sync when sewing in reverse. What I have NOT adjusted (because I don't know how) is the position of the needle bar frame, the inner and outer presser foot height. I live in a very rural area, and bringing it to a repair person is not an option, unfortunately.
